100mm fork on a bike that came with a 80mm
Old 07-10-02, 01:48 AM
Mancini
Thanks for all the help everyone. Yes Mashimaro, came here through Revscene.
Mancini is offline
Old 07-10-02, 08:46 AM
bike_man_15
listen close to mashimaro said, if you dont your f**ked, ive done the exact say thinng, but if you listen or read what he wrote, itll be fine,good luck, ohh and for the people who say its not worth it to install it on your own, it is a good expirience, therefor you know how to do it in the future
bike_man_15 is offline
Old 07-10-02, 09:46 AM
a2psyklnut
Bikes: Lots
Regarding cutting the steerer tube. Are you sure your old set-up is threadless? If it is you're o.k. If it was/is threaded then you'll need a new headset and stem.
Assuming you've got a threadless, the only confusion I saw was regarding cutting the steerer 3 mm below the stem. I would clarify that and say cut 3 mm below the top of the stem. An easier way to do it, is to use the spacers to find the proper height of the stem, then remove the stem, add another spacer, replace the stem and mark the steerer flush with the top of the stem. Viola! When you cut it, it'll be recessed into the stem!
Oh Yeah remember. Measure twice - Cut once!
L8R
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
a2psyklnut is offline
Old 07-10-02, 11:54 AM
bike_man_15
good call my friend!!
Old 07-10-02, 08:54 PM
Mashimaro
thanks for clarifying that for me a2psyklnut..it was early in the morning (sorry about that mancini!). and thanks for the vote of confidence bike_man_15
one last thing...make sure you file the freshly cut steerer smooth and blow out all the shavings...
Mashimaro is offline
Old 08-20-03, 10:57 AM
slickmobster
Bikes: 03' Kona Cindercone
instead of buying a new fork at my bike shop for about 10 dollars they can just jack it up to 100mm since its an air....ahhhh...i think i might do that soon
slickmobster is offline
Old 08-20-03, 12:54 PM
math2p14
Part of the furniture
math2p14's Avatar
Bikes: Specialized RH, Scott Unitrack
I went from 100mm to 130mm and my steering improved!!
math2p14 is offline
Old 08-20-03, 12:56 PM
Maelstrom
Wood Licker
Maelstrom's Avatar
Bikes: Trek Fuel EX 8 27.5 +, 2002 Transition Dirtbag, Kona Roast 2002
Quoted: 23 Post(s)
A good rule of thumb I was taught is 20mm either way won't change 'much' on a bikes geometry and t should handle it. I went from 100 to 130 and my steering improved but I also made some other changes to my stem to adjust the height and length of my cockpit for me.
Maelstrom is offline
Old 08-20-03, 04:16 PM
DrGonzo
bike/raft
DrGonzo's Avatar
Originally posted by Mancini
I have a question about installing a suspension fork. I have a 1995 Stumpjumper M2 with an OLD Rock Shox Mag 21 that was installed by a bike shop way back when. I just got a great deal on a new 2001 Judy XC w/80mm (3 inches) of travel.
Do you have the red specialized?
practice, practice, practice...
Last trail to kick my ass: Eagle's tail
DrGonzo is offline
Old 07-04-19, 11:04 PM
intramorph
Honestly for me i have a gary fisher mamba 29er and switched to 100mm rockshox RL solo and I love the fork. Bike came with rockshox dart 3 and those were horrible however I did feel more confident letting go of my handlebars when i had the 80mm fork. Now it's a bit weird to steer and I definitely noticed a difference in handling. I may go back to 80mm forks just because the bike feels weird. Too bad this was not a cheap fork lol and i'm going to have to take the L on it. Also I realize this is a 17 year old post lol but I just had to say something =)
intramorph is offline
Old 11-07-19, 03:22 AM
ed h
Quoted: 10 Post(s)
Liked 27 Times in 9 Posts
I'm restoring an older bike (rim brake) that has only 63mm of travel. Would like to go with Rockshox 80mm fork, but only rim brake can find is a 100mm Silver TK solo air. Question - Can this fork be converted to 80mm travel ? I know years ago my LBS was able to convert a 100mm SID to 80mm by changing just the spacers. Appreciate any ideas/comments.
ed h is offline
wheelspeed
General Cycling Discussion
1
05-24-18 05:11 AM
kwcnc
Mountain Biking
6
03-07-16 10:20 AM
remotelocal
Mountain Biking
6
04-10-15 05:56 PM
agressor
Mountain Biking
1
08-28-14 11:24 AM
nicolaim
Bicycle Mechanics
3
03-28-10 01:53 AM
