Eccentric bottom bracket question
^that guy^
In the process of converting my Cannondale R900 to a SS... Problem is it has vertical dropouts and I don't want an ugly ass tensioner. How does the eccentric BB work? What spindle would I use?
Your cog is slipping.
Aside from this kook who claims he invented one back in 2006 I've never heard of an eccentric square-taper BB that works in a 68mm threaded BB shell, so you may be up the creek.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Unless your frame is designed to use an eccentric bottom bracket, you're not likely to find one that will fit.
You could, however, use an eccentric hub, such as the one from White Industries:
This ^^^ or find the magic chainring and cog sizes , so there is just the right chain length.. to have the right tension
a half link gets you to the nearest 1/2"
here is their double freewheel flip flop version they also make the best freewheels..
single and 2 in 1..
single and 2 in 1..
^that guy^
Thanks guys... just wasn't sure how they worked
Clark W. Griswold
Quoted: 4348 Post(s)
Liked 3,985 Times
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times
I am shocked Phil is still producing the Philcentric. They just came out with a Pro alloy version even. Who is buying them?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
R+E makes the Bushnell eccentric and you may want to call or email to see they have a solution.
Worth a 30 second email to find out.
-Tim-
-Tim-
Quoted: 4802 Post(s)
Liked 3,923 Times
Ben
Clark W. Griswold
Liked 3,985 Times
My face always lights up with a smile when I see that little red script Phil logo. I know it is MUSA quality that hasn't changed and won't change.
Quoted: 481 Post(s)
Liked 131 Times
Phil isn't about trend setting new products all the time, they are about making high quality stuff for various applications. They still make BBs and cups for Swiss threads and Chater-Lea because if they don't who will and if someone can still get nice parts for their old bike, it is pretty nifty.
Clark W. Griswold
Liked 3,985 Times
I feel the same way. They recently had a post on their IG feed showing a new batch threaded EBB's being made and I couldn't believe there is enough demand. I love that they're the kind of company who will make just about anything you need if you're serious enough about it.
