Anyone running 27” tubulars?
Old 07-24-18, 05:45 PM
3speed
Quoted: 363 Post(s)
Liked 28 Times in 22 Posts
https://portland.craigslist.org/mlt/...652329866.html
3speed is offline
Old 07-24-18, 05:48 PM
T-Mar
Quoted: 4722 Post(s)
Liked 3,036 Times in 1,874 Posts
Wow!!! I wish I was in Portland. In this case, 27" is 700C.
T-Mar is offline
Old 07-24-18, 06:09 PM
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 4334 Post(s)
Liked 2,977 Times in 1,614 Posts
FREE????
Yeah, Conti AFAIK was the only maker that labeled tubulars as 27"... and their newer versions say 28". Just another way to confuse tubular newbs.
DiabloScott is offline
Old 07-24-18, 09:12 PM
verktyg
verktyg
verktyg's Avatar
Quoted: 1036 Post(s)
Liked 1,237 Times in 653 Posts
There was just an extended conversation on this topic in the Classic Rendezvous Group.
Before the ETRTO (European Tire and Rim Technical Organization) Standards were adopted by most European tire and rim manufactures, just about every country had their own standards.
700c like 650b and many other letter sizes were originally French tire size standards. The ETRTO standards measure the diameter of the bead seat in the rims rather than tire sizes: 622 = 700c tires, 630 = 27" tires.
While there were smaller wheel size tubular tires made for specific uses (600mm, 500mm, 400mm, 26", 24", 22", 20" etc.) the standard size over the past 70+ years have been 700c sized.
Before ETRTO, Continental tires used the German standard call out: Sewups were marked 27" not 700c. Here's a Continental cyclocross sewup I bought in the late 70's. It's marked 27 x 1 1/8 (it still holds air)
So yes, most tubular tires are the equivalent to 700c sized.
Clear as mud eh?
And for the newbie MTBrs, they are 700c NOT 29ers!
verktyg
Chas. ;-)
verktyg is offline
Old 07-25-18, 05:25 AM
T-Mar
During the early 1970s bicycle boom, many tubular brands were labelled as 27". Based on being the equivalent of 622mm BSD equivalent, they were technically a 28" tyre. However, the average consumer could not rationalize how a 28" tyre could be a smaller diameter than a 27" tyre, which was popular on "10 speeds" of the era. To the average consumer, they were closest to 27" and often you could even switch wheels with a minor brake pad adjustment. They were also the two sizes most commonly used on "10 speeds". So, in order not to confuse the consumer, many manufacturers labelled tubulars as 27", as that was the closest common imperial size, based on actual outer diameter.
T-Mar is offline
Old 07-25-18, 06:05 AM
John E
feros ferio
John E's Avatar
Quoted: 1390 Post(s)
Liked 1,322 Times in 835 Posts
Yes, I think much of the labeling confusion arose because of the existence of metric and English measurement systems, the wide variation in tire heights, and the need to specify brake pad height (rim radius or diameter) and mudguard / stay / fork clearance (tire outer radius or diameter). I have never seen a bicycle tubular tire that did not sit on a 622mm diameter rim.
John E is offline
Old 07-25-18, 09:04 AM
T-Mar
Originally Posted by John E
...I have never seen a bicycle tubular tire that did not sit on a 622mm diameter rim.
As pointed out by verktyg, there were several other sizes of tubular tyres, When I was racing in the early 1970s there was a Pee-Wee class racer (10-11 years old) with a custom built Reynolds 531 DB frame with full Campagnolo (Nuovo) Record group (yes, even the brakes) and 24" tubulars. His bicycle was the envy of a lot of riders.
T-Mar is offline
Old 07-25-18, 02:04 PM
DiabloScott
It's MY mountain
Vittoria still makes them in four sub-700c diameters.
https://www.vittoria.com/us/juniores-training.html
JUNIORES
Training and racing tubular for juniors, identical casing to Rally but fitting smaller wheels: 20, 22, 24, and 26 inches. Vittoria quality, feel and performance, at an entry-level price point!
Old 07-25-18, 05:42 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1560 Post(s)
Liked 1,282 Times in 853 Posts
650c sized tubulars are not rare, that was the triathlon standard for while, with a 571mm rim diameter and often referred to as 26x1".
dddd is offline
armstrong101
Classic & Vintage
29
07-03-22 08:46 AM
Yokosawa1
Road Cycling
8
02-15-19 06:59 AM
jyl
Bicycle Mechanics
19
06-10-15 12:41 PM
Project88
Commuting
5
04-19-12 12:39 PM
saigemeister
Classic & Vintage
6
11-09-10 11:35 AM
