Upgrade recommendation TRP Spyre pads
Old Legs
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times
Hello all, just got my first road bike witk disc brakes. I`d first like tp upgrade to stock pads , for dry conditions. What is a stepup or 2 from these stock pads ?
Thanks. KB
Thanks. KB
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
Some good recommendations from my thread a few days ago:
https://www.bikeforums.net/general-c...pads-last.html
I liked the BB7 Kool Stop pads.. vs Avid stock , got rid of stock, early.
KS has all brake pad types covered..
Old Legs
Quoted: 302 Post(s)
Liked 33 Times
Non omnino gravis
Look no further than the cheap-cheap: Gekors Bicycle Disc Brake Pads, $8.99 set @ Amazon
Good for at least 8,500 miles a set in my use.
Old Legs
Quoted: 302 Post(s)
Liked 33 Times
Non omnino gravis
I use the semi-metallic (sometimes called organic) with aluminum backplates. I really prefer aluminum-backed pads, as it takes less force for the spring to push them back open.
Also, pads are cheap, and rotors (particularly my IceTechs) are not. It's nice to get 12,000+ miles out of a front rotor.
Old Legs
Quoted: 302 Post(s)
Liked 33 Times
Quoted: 873 Post(s)
Liked 726 Times
I've seen some mentions of Ice-Tech being a system where the rotors work best with the associated pads. Are you getting an upgrade in performance using third-party pads on your rotors?
Non omnino gravis
I used the Shimano resin pads (G01A, I think?) for awhile, then tried the TruckerCo pads, didn't notice any difference, so I started going cheaper and cheaper. I haven't noticed a performance difference (that is, stopping power) between any of them. There are pads out there four pairs for $20. The only pads I wouldn't buy again are Giants-- they were supremely quiet, but also supremely dusty, and they wore out in like 1,800 miles. Have used IceTech rotors exclusively.
Old Legs
Quoted: 302 Post(s)
Liked 33 Times
