Sidewall cut a concern?
I sometimes obsess over the build quality of new tires. Doesn't look like an immediate thing, but I'd replace it at your earliest convenience.
Often on Fritz
Bikes: Franken-Fritz, Horse-Feathers, Junker
Quoted: 117 Post(s)
"We can't go on together
With suspicious minds (suspicious minds)
And we can't build our dreams
On suspicious minds"
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
Dollars to donuts, it is handling damage from any of those steps, I really don't think it is any sort of manufacturing issue or something I picked up on a normal ride.
Quoted: 18353 Post(s)
Liked 4,502 Times
The background in the photo is a cement sidewalk/bike path.
The damage to the tire was actually quite minimal. I can see a slight bump where the nail exited near the logo, the entrance point isn't obvious.
I don't think the casing is significantly compromised, although I suppose a hole through the casing could potentially be an entry point for debris.
I suppose I should tie back into the OP's question. In my opinion, it is fine to reinforce if desired, but choose actions based on the actual symptoms and close inspection.
I'm just barely wearing down through the center rib of my tire... and have quite a bit of wear left to go.
I have a sidewall cut similar to OP's on my front wheel tire and see some damage on the casing . I have patched inside with some rubber + a good duck tape.
I am 300+ miles after that and don't see any bump growing out yet. The tire is still on its 1500 miles ... so hope hold a bunch more
