What's the Dumbest Thing You've Ever Done
Likes For Lemond1985:
#102
Spent half an hour trying to remove a crank that wasn't budging. Banging on the crank remover arm with a hammer, frustrated to the point of tears.
"WHY...WON'T YOU.....COME OFF**********"
Yes, I forgot to remove the fixing bolt.
Likes For bear_a_bug:
#103
minimalist cyclist
Bikes: yes please
Quoted: 1119 Post(s)
Liked 1,643 Times
I guess my breaking the tension spring in my daughter's Super Grand Prix bike last weekend. I can't believe it broke and think it may have been stressed before and my hand pressure crank turning while working on it was just the final straw. The front derailleur had one of those outer pant protector rings on it that was bent into the large ring so I took that off and adjusted the rear derailleur to where it now shifted to all cogs from the small front ring. Working on the front derailleur it had been on the small ring so long it didn't even want to move, so plenty of lubricant got it moving. Somehow it jammed while still on the stand and I was really surprised & disappointed to see the rear derailleur go limp. I'm pretty new to wrenching and I was hoping to get together with @3speedslow this w/e for a wrench-fest but a schedule conflict came up.
It's a Raleigh branded SunTour according to Law, anyone have any advice or YouTube links on replacing a tension spring? I found one from RJ the bike guy but it was a more modern derailleur. Here's a couple of pics of the bent ring and rear derailleur -- help !
#104
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,059 Times
We've covered this long time ago. 1972. Age 14 . Suburbia. My first racy-road bike, 72 Orbea OCI , Zeus Alpha Junior parts on seamed tubes. Riding with pack of 15 year old peer group, smoking pot and get inspired to yell 'Evil Knievel', pop a wheelie over curb. Front quick release lets go mid air, forks bite tarmac, over bars I go, grind 3 front upper teeth into nerve screaming chicklets.
Cut to hostipal, 27 shots of freezing, 4 extractions and a lifetime of dental plates, partials and complications.
Surreptiously, I find out later that close friend had released QR as a joke. Still haven't confronted him yet after 45 years. Still a friend.
Sigh!
Sigh!
#105
A couple days ago I was rehabilitating a donated bike for our charity shop. Worked on it for a while, with distractions, then hopped on it for the obligatory test ride.
Forget to tighten the stem to the steer tube. Handlebars when one way, the front wheel another.
Fortunately, I was able to jump off and avoid a serious crash.
#106
Dumbest thing I've done ? That's easy .... destroy multiple Suntour freewheel tools trying to remove a freewheel and boogering up the freewheel engagement notches in the process to the point I had to take it to the LBS because they have a YUGE vise and were able to get the freewheel off . They took mercy on me and only charged me $20 , and honestly I would have charged me more . The experience did not make me more of a Suntour Fan to be perfectly honest, and I can say with candid honesty I have not encountered such stubborn freewheel before or since.
#107
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
All we got back then was stems and seeds. Idiots.
#108
52psi
Quoted: 790 Post(s)
Liked 802 Times
Oh, you mean bike-related.
Installing the wrong-size headset in an '86 Peloton because I went with what I thought it should be rather than, you know, measuring.
#109
Liked 7 Times
Two things, really.
1. Bought that nurse a coffee. [I STILL wake up in a sweat after 32 years!], and
2. About the same time as #1 , above, a beautiful orange maple leaf was caught in the front brake...went "bzzzzzz". Down hill about 25 knots, I reach up to remove it and get two fingers caught in the brake...jammed in there...won't pull loose. I fully stopped the bike with that jammed right hand...looking down right now at the scars. [That nurse was REALLY cute., tho'.]
Two things, really.
#110
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
One recent one... I had taped one side of the drop bars of this Univega with new bar tape, stood back to admire my work, then noticed the aero levers I had mounted and the absence of any brake housing.
Most of my builds use non-aeros, so I was just going on automatic pilot.
#111
I was working on a Bridgestone T700 bike that was previously owned but was kept mostly indoors, so it was in pristine condition. I cleaned up everything -- from the frame, lubricating the bearings, and installed new cables and housing, etc. But when it came down to cleaning the handlebar and stem, I decided to remove the handlebar. It worked out fine. But when I reinserted the handlebar, the stem was resisting and there were deep gouges into the handlebar. The only error in an otherwise immaculate condition bike
#112
Quoted: 472 Post(s)
Liked 1,028 Times
#114
Bikes: Lots of French, some British and a couple of Italian
Quoted: 247 Post(s)
Liked 130 Times
Tried to make a 30lb C&V lighter. It was for the OH. it's lovely, but I'm so ashamed I've never put a photo of it anywhere on here.
#115
Quoted: 7349 Post(s)
Liked 2,474 Times
This isn't the dumbest thing I've done, but the most recent dumb thing I did was to put Octalink V1 cranks on an Octalink V2 spindle. Folks here on BF helped me figure this out. So today, I put in a V1 spindle, but damn it, I've chewed the insides of the cranks up! Now the cranks are toast. And I have some BBs I can't use, either.
#116
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
Maybe this is a bit older then C&V, but harken back to Camelot (circa 1962). It is spring and we (aged 8-11) decided when we were out on our Columbia and Schwinn balloon tired bombers, that riding was too tame and we needed a change-up - to broom jousting!
Mounted on our trusty steeds at 15 yards apart, one took a broom, bristles forward, a bucket (steel or plastic) with eyeholes for a helmet, and faced the opponent. A fast acceleration and contact, hopefully to mid-chest, with the broom would unhorse your opponent. Worked for two rounds until the contact caused two riders to veer into each other with foreseeable (now, not then) results. Broken spokes, bent fenders, headlight batteries on the ground, cuts and bruises, just as some parents decided they HAD heard a crash and decided to check it out.
Yelling and scolding colored the air, and all bikes, buckets, and brooms were on lockdown. Yet we all managed to survive until the thought of riding without a helmet would be unthinkable. No kneepads, no gloves (helmets-yes ). Fun? You bet!, Stupid? Yes! Memories? Hilarious and lifelong!!!
Plus we all definitely learned how to fix bikes.
Likes For Bill in VA:
#117
Not bike related, but this ^^^^^ reminded me of something my brothers and I used to do. When we were around 5, 7 and 10 years old (I was the middle one), we would put on boxing gloves, go into a windowless room, close the door and light, and just swing away. We laugh about it now, but with the crap we did as kids, we're lucky we're still walking this earth.
#118
Quoted: 535 Post(s)
Liked 346 Times
For context, I should start by stating that my bike is currently set up as a single speed. I’ve been planning to switch it over to a 6 speed, but haven’t quite gotten to it yet.
Well, today I went out for some errands. I kept hearing a steady rattle coming from the bike somewhere. I was a bit busy so I decided to wait until I returned home to check it out.
Probably 2 miles round trip at most, with a couple of stops along the way. An annoying rattle the whole time.
Just about home. In fact I had just crossed the last street and arrived at the driveway to my apartment when I hear a noise behind me. I look back, and see smack dab in the middle of the sidewalk, a 1st gen Superbe rear derailleur!
Suddenly it dawned on me that two days prior, I had threaded the RD to the hanger just enough to see what it’d look like on the bike. A few threads at most.
And suddenly it dawned on me that forgetting to remove it, especially before taking the bike out for a ride, has got to be the dumbest thing I’ve ever done (C&V related of course)!
Likes For deux jambes:
#119
Story One:
Trying to make a slow 180 turn while staying on the bike path. Of course at 6'4 and sitting tall top heavy in the saddle the physics didn't cooperate and down I went. I broke my fall when I reached out but my palm hurt for 6 months. I guess it was fortunate I had on gel gloves at the time.
Story Two:
Unclipped with the right food and leaned left. I realized in mid-fall what I had done wrong. Luckily the light was red so I just lay there splayed on the asphalt. Undamaged other than my ego.
#120
Quoted: 2338 Post(s)
Liked 2,827 Times
Sunday I unscrewed a set of dura ace 7400 levers 100% off the mounting post/band Idea being to save time (first warning of a mess coming) not running them off the bars to put rustines hoods on. Immediately the little bolt with plastic thingy that screws into the mounting post/band pops out of alignment. No problem simple to put back......but nooooooo! fought it for almost an hour, taking the other one off also so i could see the alignment.....and of course it pops loose also. next a small washer drops on the floor ...find it after t minutes. then i drop the little bolt plastic thingy, find it after 10 minutes looking.... feel into my tool bucket. At that point I put everything in plastic tub and had a beer. Will try again tonight
may not be the dumbest thing I've done but way up there on the frustration chart
#121
Bikes: '09 Felt F55, '84 Masi Cran Criterium, (2)'86 Schwinn Pelotons, '86 Look Equippe Hinault, '09 Globe Live 3 (dogtaxi), '94 Greg Lemond, '99 GT Pulse Kinesis
Quoted: 389 Post(s)
Liked 270 Times
Back in the 70s, we were on a pick-up truck road trip from California to visit North Dakota relatives. Mom asleep, sis asleep in the back of the truck with me, Dad bored & staring ahead at the empty, endless Utah interstate. Ensuring no witnesses, I reached over the side of the truck and felt the +/- 60mph spinning tires with my fingertips.
I waited until I was 38 before telling my parents about that and they still froke out. I was maybe 4 or 5 when I did it, but no statute of limitations on that one, apparently.
Likes For calamarichris:
#122
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I wish I had slow motion video of this one
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
#123
Disco Infiltrator
Liked 2,105 Times
The sequel. At least I took out the balls first this time
#124
Quoted: 5224 Post(s)
Liked 3,584 Times
gave up my dream job for the girl of my dreams
Likes For rumrunn6:
