Will you ever go disc?
#276
Ride, Wrench, Swap, Race
Quoted: 1562 Post(s)
Liked 1,287 Times
Wow, that was timely!
Wondering if these levers can be used with any of the older hydro sti levers?
(I would expect not, unless they knew they had these in the pipeline)
#279
Quoted: 4717 Post(s)
Liked 1,882 Times
I would expect them to be compatible with other Shimano hydraulic systems, but hooking them up might be a PITA if you don't know how to cut hoses + bleed your brakes.
#280
Quoted: 37 Post(s)
My argument for disc brakes would mostly be the consistent wheel alignment provided by the thru axle. I had a previous rim brakes bike which developed some play at the dropouts, which resulted in wheel alignment issues. No more of that with thru axles.
If they could actually make rim brakes bike WITH thru axles, I'd be delighted.
#283
That wouldn't have anything to do with the flavor of wheel retention device being used.
-Bandera
#284
Single speeder
I think cost is a component here. When disc brakes get so cheap, most everyone will just use them. Rim brakes will always be around since there are a lot of frames that don't aren't setup for disc, and there is a desire to keep the vintage of the frame.
#285
Well; today when I got my disc brake road bike down I found the brakes were bottoming out. I pulled out the hydraulic kit and bled the brakes, getting fluid everywhere. When I finished the brakes were up to their proper level but the pads were contaminated and squealed as the bike comes to a stop. I took my mountain descent fast and tried to burn off some of the fluid which seems to have worked, but I now may need new pads.
Adjusting hydraulic brakes is a pain. My old rim brake bike is a pound lighter and the brakes are more reliable and easier to adjust.
I probably wouldn't buy another hydraulic disc brake bike.
#286
Quoted: 20808 Post(s)
Liked 9,450 Times
#288
Liked 1,882 Times
Every YouTube brake bleed video I've seen, advises you to remove the pads when bleeding.
#290
Liked 9,450 Times
On top of all that, when he says that he got his bike down, I'm wondering if it was hanging and just got a bubble or two in the line that could have been remedied with a little pumping of the brakes while tapping on the lines with a screwdriver handle or something.
#291
Bikes: '04 Cannondale T800, '00 Raleigh M80
Quoted: 11 Post(s)
In answer to the original question, no.
I have rims now and they work fine. I have no pressing need or desire to switch to discs.
I have no argument against discs. I have zero experience with them, but by most accounts they seem to work well and people seem to like them. Nobody would buy them if that wasn't true.
If I stay with rim brakes it will be because they are simpler and less expensive to maintain. I like cheap and easy. :-)
#293
Bikes: Specialized Ruby Sport
Quoted: 318 Post(s)
Liked 314 Times
Me too. And I'm really sad I won't be able to replace my car with a newer model with manual transmission. They stopped making the Beetle with stick shift a couple of years ago and they are stopping production altogether this year.
#295
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Must have been NOS.
In other news I had my first client who forgot to mention they were wheels for a disc brake road bike - not rim brake. He seemed confused as to why I would ever think any new road bike would have been rim brake.
Before now road disc users were a bit like crossfit members or vegans/vegetarians : they told you about it in the first sentence or two. Now it appears there are those that just think it's the new norm.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
#296
Bikes: Yes please
Quoted: 536 Post(s)
Liked 308 Times
Like many others mentioned, the choice has been made for us as it seems . I’m getting back on the road after a couple of years of hiatus and thought I’d build a new bike. Many of the new frames I’d like to build upon doesn’t even have a rim brake option.
I can lock the rim brakes, and I don’t think having disc brakes lock up earlier would do me any good. I understand the point about brake fade, but I don’t do any technical descents, and even when I have a steep downhill to cross, I keep my speed under check, as I’m scared s-itless that my only contact patch with road is two 1/8”-1/4” wide by (perhaps) 1”-2” Long strips of rubber.
#297
Liked 1,882 Times
With hydraulic disc brakes you can modulate the braking power better, with very little effort on the lever.
Discs also eliminate rim wear. Some rims cost $1000 each, and some wheelsets are over $6000
https://road.cc/content/review/22033...-c-disc-wheels
Likes For noodle soup:
#298
Kit doesn't match
I imagine that @oldbear63 knew that he was responsible for screwing the pooch. I imagine his point was that it's a good bit harder to royally screw up when adjusting rim brakes than hydraulic disc brakes. It's not rocket surgery, but it does require more experience to fully service hydraulic brakes.
#299
Liked 9,450 Times
I'd disagree with that. My first experience with hydraulic brakes was installing them on my own bike. Shimano's instructions are pretty clear and I didn't make a quarter of the mess or difficulty that that guy had.
#300
Kit doesn't match
As I said above, I don't consider maintaining hydraulics as especially difficult, but I do see it as a fair more of a pain then rim brakes.
Likes For GuitarBob:
