Who makes the STIFFEST sub 1500g clincher wheelset?
Check out the Ritchey WCS Protocols. Bicycling magazine found these to be the stiffest of the 3 "mid" priced wheels sets they reviewed. You can find the review at the magazine's website.
Ira
Ira
Making a kilometer blurry
Are you looking for lateral stiffness or radial stiffness?
Location: "Gosh honey, you pass more like Tony Rominger..."
Bikes: 2005 Scott CR1 Pro - 1992 Panasonix Fixed Conversion 60tx20t
"How did all those 'Keep Off the Grass' signs get there?"
Campy Proton or Neutron with rear off-center spoke hole drilling should be good too, and the newer Shimano wheels with off-center spokes should be good as well (same patent Ritchey is licensing).
Any deep section wheels are going to be more laterally stiff than similar spoke count lower profile wheels. The spoke angle gets further off perpendicular with a deeper profile, which makes for a more triangular geometry.
I'd research the deep carbon Zipps.
Bikes: Litespeed Hyperion, 06 cervelo soloist team, 69 motobecan grand touring, 72 motobeacn grand touring, 2004 giant OCR3 converted into a TT bike
Zipp 404 clinchers are very stiff, also mavic carbone pros, campy boras. Or you could go tubular and buy a set of light weights
Rams Cycling Team
'06 Cervelo Soloist Team record, '04 S-works epic sram and king equpied, '03 litespeed hyperion DA/Ultegra 10sp
Rams Cycling Team
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
Everybody says that, but it hasn't been my experience. Out of the saddle I can flex the rear enough to rub the brakepad pretty easily. To the point I have to flip the quick release open going uphill.
Let's Go!
Bikes: 2005 Trek 1500
Mike Garcia at www.oddsandendos.com Give him a call and he will take good care of you.
What about the Topolino wheels?
Whateverthehell
Bikes: '06 Blue Competition RC5AL w/ritchey pro fork, spinergy stealth PBO, etc.
topolinos are pretty stiff, but on my last two climbs up palomar, i've experienced a little brake rub. this, though, is more due to there being a little play in the hub. the first time, i didn't have the tools to rectify the problem while on the ride, then i totally forgot about it before putting them back on the bike and doing the same ride a few days later.
actually, thanks for reminding me. gonna go fix that right now!
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." - Leonardo daVinci
Everyone claims the Ksyriums are stiff wheels... but they really aren't. See #96 and #97:
https://www.sheldonbrown.com/rinard/wheel/data.htm
Strength of a wheel is important, but I don't think stiffness is really an issue unless it gets extreme. If the brakes are rubbing, then open them up a little.
Sick ... again
Originally Posted by rruff
Knowing Buycycling Mag, they probably didn't actually test for lateral stiffness... they just went by "feel". Opinions like that are useless since feelings can be all over the place, plus they don't isolate the variables... ie other things are changing besides the wheels.
Bikes: Cervelo R3, Moots Vamoots SL, Litespeed Classic, Trek 5500
I don't think they are less than 1500 grams though!
Mad Scientist
Bikes: Dean TI fixie... Viner ProComp... NEXT pink sparkely!
unless you're running cheap wheels (which i don't), is lateral stiffness that noticable or that important? i was just curious because i like to spin up hills on the geared bike and i'm not heavy, so i don't notice lateral flex... now on the fixed gear, i have to mash up some of the bigger hills b/c i run a steep gear, but i don't have brakes so i don't really notice flexing or rubbing
burp
Stop it.
Bikes: 2003 Specialized Hardrock Pro w/ slicks, flipped stem and HB, 2003 Colnago Dream with full Dura-Ace 7700 double, 2001 Bianchi XL Boron/Daytona, Mavic Open Pro/Campy Centaur/DT Champion built wheels.
Topolino Revelations C19's.
Ca-na-da?
Bikes: none at the moment
Originally Posted by SDRider
Ksyrium SLs are quite stiff and very close to 1500g.
Get on a cross bike.... you'll like it ;)
