Leader LD-720TT
Leader LD-720TT
Hello all, I am a new member to the forums and generally to riding.
I am looking to build a fixie, now I can of course purchase a frame if needed but my uncle has a frame he offered me, a Leader LD-720TT. Now here is a picture of it:
Is this frame at all possible to work with or turn into a fixie?
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
Yes*
Due to vertical dropouts, you'll need either a white industries ENO eccentric rear hub OR a special combination of rear cog and front chainring teeth for a "magic gearing" that provides sufficient chain tension.
Ahh, okay well I may have him ship me that one then after all
Ths Hipstr Kills Masheenz
Bikes: tirove
it will also be a much nicer frame with an ENO eccentric white hub than anything else you'd get for free plus a wheel with an eno...
you should really consider building it geared though. gears man. gears.
I was thinking about it, I may build this one with gears and purchase or see what else my uncle has lyin around, something with horizontal dropouts hopefully.
Quoted: 1332 Post(s)
Liked 398 Times
It would make a rad single-speed too. Building it up geared would be awesome but also quite expensive.
Fresh Garbage
Liked 398 Times
True, but even on the used market a decent groupset could set you back $4-500 pretty easily. And then factor in labor cost for the build (unless you have a hookup).
Fresh Garbage
Yeah, what can you do? Road bikes are generally more expensive - road vs. track of equal quality
Goes to 11.
Bikes: 2015 Soma Double Cross
I thought i saw recently that ENO hubs on aluminum frames == chewed up dropouts.
Your cog is slipping.
Bikes: Self-built EightInch fixed-gear.
Please build this up geared. You can easily do it for $500, and it would be a way better bike, I think.
JensonUSA usually has some great take-off build kits, like this: https://www.jensonusa.com/store/produ...Valle1+08.aspx
Liked 398 Times
That one seems a little oddball, what with the flat bars and canti brakes, but I do see some sets on that site that I would definitely consider.
Bikes: Cannondale CAAD12, Specialized Rockhopper, Norco Fluid FS1
Quoted: 127 Post(s)
how come leader doesnt make any more geared road frames other than the 722rs?
Bikes: Pake,Shogun,Nishiki,Motobecane
Liked 398 Times
Their road frames don't make them enough money. People who want to build up ****** road bikes just don't shop at Leader.
