Copper bar end plugs?
Anyone know of a source for copper (or copper plated) bar end plugs for drop bars? Ideally something that looks vaguely retroesque, but at the very least something aesthetically neutral and not overly branded with modern looking logos.
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
I think rootboy has been lathe-turning some very nice brass numbers...maybe he can try some in copper (or bronze).
https://www.bikeforums.net/showthread...rass+bar+plugs
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Maybe plumbing supply?
Check out www.djcatnap.com for articles on vintage Japanese & French bicycle restorations, components and history.
Bikes: ritcheys{2** rm blizzard Geo elrick drop frame and acollection of parts bikes in waiting
Take a old pair of bar plugs , drill a penny ,countersink use brass screw .Old brass buttons
Old fart
Liked 3,400 Times
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times
Not sure if this would fit the bill, but Cinelli makes alloy-covered bar end plugs in a range of colors, including an orange that looks rather coppery.
https://www.ebay.com/itm/Retro-CINELL...item43c354d36e
Bikes: Bullitt Milk Plus with Alfine 11s; Dahon Smooth Hound
You have probably considered this already, but I'd be wary of using copper in an alu handlebar because the alu might corrode quite quickly because of dissimilar metals.
Of course, if you check frequently and/or give the whole thing a new wrapping regularly, I wouldn't worry too much. Anyway, just a thought.
Your point is what, exactly? That there is no problem dissimilar metals going on with attaching copper to alu because brass is an alloy?
Stainless steel is an alloy too, hell most titanium stuff you buy is also an alloy.
Btw, your brass plugs look very nice, and since they are separated from the bar itself by O-rings, I don't see any problems arising with that set up.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
+1 on the possible dissimilar metals issue, especially if you ride a lot in the wet........ Although if you are careful enough, you can possibly avoid all contact between the two different metals if you carefully wrap the bar end stub completely with it, before inserting them into the aluminum handlebar ends. No contact = no electrolytic corrosion...
Quoted: 556 Post(s)
Liked 132 Times
No, my post had nothing to do with the dissimilar metals issue. It was only to illustrate that solid brass ones …which is mostly copper...are available, if so desired. And while I don't have any copper bar stock on hand, I do in brass.
Quoted: 196 Post(s)
Liked 6 Times
You could also make some bar-end plugs from spent shotgun casings.
Spin 'em from a small disc. Probably way more work than it's worth but might be cheaper than machine solid copper.
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
Have you check into Purely Custom?
https://www.purelycustom.com/p-56-dom...-1-bar-id.aspx
I have no idea if the copper one actually looks like copper or anodized.
Real cyclists use toe clips.
jimmuller
jimmuller
steel is really easy to copper plate. spring steel end plugs are cheap and (maybe too) common.
Quoted: 1627 Post(s)
Liked 630 Times
You would need to take some acetone to the white letters on these, but they could work.
