Changing bottom bracket to a cartridge unit?
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
I'm thinking of changing the bottom bracket on my 85 Sequoia to a cartridge unit but I'm not sure what I need.
The shell is 68 mm and the spindle is 114.5mm but as near as I can tell the drive side is 4mm longer than
the non drive side. Here is a photo of the spindle.
Really Old Senior Member
Is there another mark on it such as 3-S, 3-P etc?
Quoted: 677 Post(s)
Liked 460 Times
Here's a different chart that lists your size.
Basically, you want to match up the DS since the FDER is related.
NDS, do the best you can.
Looks like a 113 or 117 are your options.
Your FDER must be capable of the additional 1.5mm of travel, so you might want to select the one that "centers" best with your FDER.
Also, if going shorter, that the chain ring doesn't rub the stay.
