It is okay to walk up steep hills
#101
Quoted: 2333 Post(s)
Liked 2,097 Times
hour long steady 15% climbs are vry rare. I can only remember a couple in my whole life, they are out there.
if you could find one, doing it on a trike with a 7 inch gear would be a piece of cake. You could stop, lock the brake, have lunch, and continue on spinning at 90 rpm without any worry about balance. Can only speak for myself, this would be a zone 1 effort. Slow but the hill would be easy. How do you get such a small gear? Small wheels, large cog in the back and a Schlumpt mountain drive up front. Pretty common on trikes. The guy flaming the 84 year old should be given a time out by the mods. Ignorant and unnecessarily rude even for BF
#102
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,648 Times
Winds this weekend were steady 20-25 mph with gusts to 40 mph, straight from the south. I explored a new route that was a fun 40 mph downhill blast with a tailwind, but I knew it was gonna cost me on the return leg.
The undulating uphill grade back into the headwind averaged only 4% but had some double digit sections of 10-12%. My go-fast bike Saturday has a 12-23 cassette. With a 39T small ring, dead legs and that combination of hill and wind, I was crawling at 5 mph on the steepest section for about a quarter of a mile.
I thought of those old school hardmen of the 1940s-60s, grinding up climbs so slowly that fat old men carrying wine bottles and baguettes were able to jog alongside the cyclists.
Not today, Alfonso. Not today.
I was pretty close to getting off and walking, but Look Delta and Shimano SPD-SL cleats are terrible for walking. I'm not embarrassed to admit I veered off the street and pedaled up a narrow sidewalk for about 100 yards, at which point it became a proper wide, freshly paved multi-use path. Brand new housing development, hardly anyone out here yet. No witnesses to my shame.
Sunday wind was even worse. This time I took my old faithful steel bike with relatively comfy 50/38 chainrings and 13-28 freewheel. And I'm considering switching that bike to an 8- or 10-speed wheelset with 12-32 cassette for just such occasions.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
#103
Quoted: 4560 Post(s)
Liked 2,802 Times
After raising the stems and handlebars on most of my bikes, I can sometimes manage 90 minute rides before the neck gets uncomfortable. But it's not so much the drop between saddle and handlebar as the alignment of my neck and back. If I didn't need to look up at the road occasionally I could handle my road bikes with slammed stems and 3" or more drop. It's the slight craning upward of my head that causes pain.
I might switch my Ironman back to the 90mm stem Robbie Tunes sent me a couplafew years ago. About two years ago I replaced that with a 120mm stem, but even with the bar raised nearly to saddle height it starts to get uncomfortable after an hour or two.
Likes For canklecat:
#104
Not that I am a billy goat, yes I have... we have an event locally called Horrible Hilly, I run a 11-26 and the last climb to the finish is long enough that I have had to get off to stretch and walk a few times, it was in my part pushing it too hard early on in the ride, not enough food/hydration to finish strong.
So I have no issue seeing anyone walk, been there myself.
Likes For InTheSticks:
#105
Bikes: Bicycles? Yup.
Quoted: 482 Post(s)
Liked 1,593 Times
Once, on the steepest part of a local hill (19%) I felt the front tire lift. The bolt of terror was memorable and I was WAY over the bars for the last bit of adrenalin fueled climbing.
#106
there are hills even on my Bosch mid drive are so hard. this guy tops out at 22% grade. to get the max out of my motor I had to keep the rpms at 70rpms or above I had to put out 520 or so watts and thats a lot for me for 2 blocks. now if I can only keep the rpms around 40 like usual they I can do it at 450 watts but it feels harder.
one of my big complaints about e bikes is the gearing is now low enough for steep hills.
And a Bosch mid should be ideal for that sort of hill. So you're saying that the gearing is not low enough? You mean the cassette?
#107
Quoted: 680 Post(s)
Liked 949 Times
right the bike came with a 11-42 cassette but for the commuting and such I do the 11-32 has much better spacing. I wanted to try this hill with that cast but I have been too lazy its also like 900 feet of climbing with a lot of it 16 to 18% grade to get to it. a 2.5 mile right with 900 feet of climbing all of it in a mile or so. I have been debating on putting on a 42t chain ring so I can climb more efficiency but I don't really need it. I can do a 18% grade in tour and do 14mph if I feel good.
#108
just another gosling
Quoted: 3890 Post(s)
Liked 1,939 Times
I have walked up 2 hills, both of them when my wife and I were doing loaded touring on our tandem. One was steep gravel and the rear wheel just spun though we didn't fall. The other was 19% and we just blew up. The interesting thing to me in both cases was how hard it was to move the bike uphill, actually much harder than riding it had been, but because we were going so slow walking, our HRs were lower. We noticed other riders, not touring, who were walking their bikes up hills we had ridden up. This was in our mid-60s and neither of us is a strong rider. We just ride a lot. We did a pass climb between the Czech Republic and Germany, Pass Strasse, 15% IIRC. We just stopped every few hundred yards until our HRs became slightly reasonable, then had at it again. That said, it's way easier to start on a hill with a tandem than a single.
It also helps a lot to have good pedaling technique. An excellent training aid is to practice climbing some moderate hill in a huge gear, so that you are pedaling very slowly, say 50 cadence, and not moving your upper body or prying on the bars, just your feet going around. When I was training on a SS, I'd climb really steep hills at a 35 cadence, seated. Of course that means foot retention. No foot retention and you're walking.
Anyway, as I'm sure other have already said, gear your bike so you don't have to walk. On our tandem at 150 y.o., we have a 26 X 40 low gear. On my single, I have a 26 X 30 low gear. These are totally reasonable gears. I have a 24T granny ring for the tandem, but don't need to put it on . . .yet. The trick for gearing is to use a small chainring so that your cassette won't have huge gaps. IIRC, Machka once posted about riding loaded up a mountain pass in Colorado at 1.5 mph. That's probably a lower limit! It's still faster and easier than walking the bike. Bicycle calculators are very useful for figuring out what gear combo will enable you to climb That Hill seated.
Results matter
Results matter
#109
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
Yes. There are a few hills in my neighborhood that are so steep they should have stairs cut into them. They're not really hills, actually; the geniuses who laid out the roads around here just went straight up and down the sides of ravines, in one stretch, three or four in a row. It could qualify as a roller coaster. One has a name: Blister Hill.
Likes For rollagain:
#110
What happens when you try to pedal up? And the small front ring is 42 or something?
It seems even worse to also have to push an ebike up a hill.
#111
Liked 2,097 Times
I walked 5 hills on one 300k brevet and that was in a PBP year. IIRC, I finished first. It was 100F with high humidity. Life is not always simple and sometimes a little compromise helps.
When I was young and foolish, I refused to walk until I hit a 25% hill in Wales when touring with 100 pounds. I came to a stop. Fell off. Rolled down the hill. It was raining and the road was slick. A motorist stopped and asked why I did not walk or take the road around the hill. The proper response would have been that I am young and dumb
Likes For GhostRider62:
#112
Quoted: 680 Post(s)
Liked 949 Times
I would think that the mid drive would mean that it could climb the hill on the 32t cog. I have a 34-42 low gear for hills like that but it is my pedal bike.
I have a 18% grade thats about 1 block I go up daily. I can go up it fast and be lucky to hit 400 watts. I can go up it in eco or tour really well with my gearing.
#113
I climbed it I had to put out 450 wats if I could not keep it at 70 rpms and 520 or so if I could keep it at 70. my older Bosch I could only do 450 watts. I have a 46t chainring. I may put a 42 on it later. but I don't have the bike geared to spin on that steep of a slope. you need to put at 70 rpms to max out the motor.
About what speed do you go up the hill in the photo?3
#114
Grupetto Bob
Liked 5,648 Times
In Washington state, it is illegal to walk your bike up a hill if you have shaved legs.
Likes For rsbob:
#115
Quoted: 680 Post(s)
Liked 949 Times
I forgot about speed. on the one bike when I did 450 watts I could only peddle about 40 rpms and went up around 5mph or so. at 520 I think it was 7 or 8 spinning at 70 rpms. somewhere around there.
#116
Palmer
Quoted: 1671 Post(s)
Liked 1,826 Times
Top hill walking tip: MKS or Wellgo quick-release pedals. Dismount, pop that pedal off and walk normally, close to the bike, ankle-bruise-free with no awkward lean.
#117
Professional amateur
Bikes: Does a Big Wheel count ?
Quoted: 302 Post(s)
Liked 136 Times
I've recently found that I enjoy walking uphill a bit during rides. But, it's not because I cant ride it, but that the backs of my legs sometimes get really tight, and I've found that walking uphill, even just a few yards, stretches everything out and gives me brand new legs!! So lately, I'll recognize it, and maybe 1-2× per ride, just hop off on a steep incline,and walk up just a little ways, and all that tightness and discomfort goes away (it's almost bizarre how much even 20-30 seconds walk can help). Its probably age related (pushing 60 now), and my racing and hard training days are well behind me ,so im just riding for fun and cardio/weight control, with nothing to prove, so it works for me.
Likes For Brocephus:
#118
Bikes: yes, i have one
Quoted: 1139 Post(s)
Liked 1,182 Times
me I did 450 and 520. 520 about did me in going up that hill. heart got to 170bpm. it would be interesting using one of those calculators to figure total watts to climb such a hill then you can see how much the motor is doing. when I do around 520 I hit the max the motor can put out over time. I can do really short 600 to 700 bursts and it does not feel like the motor ran out but thats for only 10 seconds or so.. But I bet the motor is putting out 350 watts thats its nominal rating.
#119
I walked it today and overall I think it was okay. I didn't feel out of breath or very strained. My bike was light enough that I didn't mind pushing the bike. I think the physics have something to do with fighting backward roll of gravity making pedaling inefficient compared to walking.
Likes For adlai:
#121
Quoted: 4416 Post(s)
Liked 4,872 Times
5 mph is very hard work on a 22% slope. Bike calculator suggests it requires around 500W for an 80 kg rider on a 15 kg bike. People tend to over-estimate their climbing speed on bikes.
#122
Liked 1,182 Times
if i recall correctly i used a bike calc and found teh speed to be ~9mph @ 800W with similar weights. that made more sense to me.maybe the rider is a bit heavier.
#123
Liked 4,872 Times
In my limited experience of e-bikes they tend to stall out on very steep climbs, so probably not contributing 350W at that very low cadence. The above physics certainly suggests he is not making 800W total. Seems more like 500W unless weight is very high. My friend has an e-bike (Orbea road bike) and his definitely struggles on gradients above 20%. While he can easily cruise away from me on a typical 7 or 8% slope, I can actually pass him on very steep slopes above 20%.
Likes For PeteHski:
#124
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
I'm just getting over corona-virus, so for my first time, I had to get off the bike (Rudge Sports) on a few hills last week. No problem. "Reality used to be a friend of mine..."
#125
Standard Member
Liked 940 Times
Likes For 1989Pre:
