Derailleur limit screws should just be Left and Right
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,648 Times
The limit screws are NOT used to center your chain over the gear/s. The barrel adjuster attached to the cable running to your derailleur is used for that. As pointed out above, the Limit Screws are only used to keep your chain from being shifted into your spokes (L) or into your frame (H). For the barrel adjuster, turning clockwise adjusts the derailleur outwards and vice versa.
this is an excellent How To video
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 3514 Post(s)
Liked 2,927 Times
In fact, for some (most?) Shimano rear derailleurs, the high limit screw IS used to dial in the initial position in relation to the high gear sprocket.
After that is set, the cable is adjusted.
Likes For smd4:
Quoted: 506 Post(s)
Liked 639 Times
This. There are way too many different designs, and many derailleurs have no H or L markings. Just look at the darn thing and figure out how it works. Couldn't be more simple.
Klaatu..Verata..Necktie?
Quoted: 10440 Post(s)
Liked 11,914 Times
I don't know what the hell you people are talking about, with screws labeled "H" and "L". I just looked at mine, and they're clearly "+" and "x".
Likes For genejockey:
52psi
Quoted: 790 Post(s)
Liked 802 Times
Heh. That one took a moment to process, but I got there.
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
It's not a problem. Ever.
Even if it was, shift into the highest or lowest gear and turn the screw, see what happens.
Likes For rosefarts:
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
I don’t see a lot of the models of derailers you are talking about because those just aren’t in the pipe line. Most all the derailers I see are 9 speed but that is likely the bulk of derailers that most people are going to see. I’ll agree that if you can see the stops the whole process is easier but there are vast numbers of derailers…front and rear…where the stops simple cannot be seen from any angle.
Stuart Black
Stuart Black
Liked 11,914 Times
Quoted: 2604 Post(s)
Liked 1,933 Times
Likes For pdlamb:
Liked 11,914 Times
