Chainring BCD 144 for 3/32" 9/10 speed chains
Bikes: Klein Quantum
Is it possible to get a chain ring (5 bolts) in BCD 144 for 3/32" 9/10 speed chains?
I want to use a Miche track crank on a bike with 10 speed SRAM cassette. I will prefer a 50t, 52t or 53t chain ring.
Is this possible? .....and where can I get it?
If not......do you have a suggestion for a good crank + chain ring (BSA, ISO square) with only one chain ring?
I am searching the web in the moment to see if I can find something. It seems the older Campagnolo Record chain rings are 144 BCD? https://www.ebay.com/itm/Campagnolo-N...item53f687fec1 could such a ring be used? ...there is also the "thickness" of a tooth ....if it fits a 10 speed chain.
Yes, that is the question in the moment. I also found that Blackspire makes some BCD 144, 3/32". But again.....there is the question about the narrow chain. The next is to find a dealer which sells them. Many has Blackspire......but not the BCD 144, 3/32" rings. https://www.blackspire.com/qs/product/83/5948/263229/0/0
Quoted: 1217 Post(s)
Liked 187 Times
There is a gentleman in Finland who would love to accommodate you:
https://www.bikeforums.net/showthread...fferent-prices
Thank you! ......I will try go get into contact with him. I have not posts enough yet to be able to send a PM. I work on it.....
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
https://www.ebay.com/sch/i.html?_nkw=..._from=&_ipg=50
That is good so I can use my Miche track crank for road use. I only need a confirmation that the 144mm BCD, 3/32" rings can take a 10s chain (e.g. a SRAM PC 1071).
Quoted: 86 Post(s)
maybe ask the question of whether or not a Campy 3/32 chainring will work with a the 10 speed chain that you plan to use, as has been mentioned.
Yes I have asked this question to an ebay seller and also to the guy from Finland in this forum. In the meantime I got answer from Blackspire and their 144 BCD 3/32" chain rings are made for 10s chains. They also provided my with a company name in Europe (Holland) where I should be able to get it.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
heidibsmith
Classic & Vintage
3
03-28-15 01:35 PM
bennie222
Bicycle Mechanics
4
02-21-11 10:49 AM
