Bike rack solution for commuter?
Just got a single speed bike (6KU Fixie) in hopes of having it as my new commuter. Also bought the Planet Bike Eco Rack to go along with an Ortlieb pannier I was given. My bike has no eyelets/braze ons, so I'm trying to figure out the best solution. 4 P-Clamps? 2 P-Clamps at the bottom and a seat post clamp with eyelets? Any ideas?
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
Seatpost clamp rack mount and a pair of p-clamps at the bottom. The clamp rack mount works best with larger frame sizes where the clamp is close to level with the rack. On small frames the rack front support arms will angle down sharply and pinch together very closely at the clamp and overall the rack will be a bit wobbly with heavier loads. There are rack mount clamps available that simply wrap around the post and don’t serve as the seatpost clamp. You can raise that type of clamp up on the seatpost to match the height of the rack and avoid the sharp bends to the support arms.
Unsolicited advice — put a small piece of frame saver tape around the seat stays before mounting the p-clamps at the bottom. When you eventually decide to remove the rack, your frame will still look pretty.
-Kedosto
-Kedosto
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
If you must, Topeak makes a rack that clamps to the seat post and has lower struts for side bags. I’m sure they’re not the only ones. But really, a backpack or messenger bag would go better here.
Tubus P-clamping system.
https://www.sjscycles.co.uk/carriers...stay-mounting/
Read the reviews.
Don't buy parts at a hardware store to make it work, but a nice system (this one will minimise paint damage and facilitate a secure fitting.)
Different diameters exist:
https://www.tubus.com/en/products/ac...uct/clamp-set/
Read the reviews.
Quoted: 1188 Post(s)
Liked 1,154 Times
And for the bottom https://www.sjscycles.co.uk/carriers...nting/?geoc=AU you could easily drill the holes out for a 10mm axle. Or make your own out of flat bar, 10mm hole, 5mm hole, hose clamp around bottom of rack stay and flat bar to stop it rotating.
the tubus stuff is top notch.
Since I don't have at the bottom?
I have a Planet Bike Eco Rack. https://www.planetbike.com/store/eco-bike-rack-599.html
Quoted: 564 Post(s)
Liked 350 Times
I’m not a big fan of mounting at the axle because any time you remove the rear wheel, the rack gets involved. If you go with the p-clamps at the seat stays you can flip the bike and pull the wheel and the rack is not involved. Though the axle solution does look cleaner.
Years ago I tried a axle mount solution from Axiom (can’t recall for sure) and it was a pain in the butt.
-Kedosto
-Kedosto
Thanks, that's helpful.
At this point, I'm between doing 4 P-Clamps for my Eco Rack or buying a seat post rack that has clamps on to my seat stays. Not sure which one is better...
https://salsacycles.com/culture/bett...lternator_rack
I actually did this on one of my kids bikes by bending these long flat attachment arms that came with the rack.
https://www.amazon.com/Topeak-Extra-...16959481&psc=1
4 P Clamps would be my vote, on a fixie you don't want the rack setup interfering with chain tensioning by moving the rear wheel in the horizontal dropouts.
And, mounting the rack on the seatpost could impede saddle height adjustments, if you're a fan of doing this frequently..
dchsueh
Bicycle Mechanics
11
06-28-16 05:23 PM
gholt
Commuting
11
08-02-10 08:52 PM
