Clydesdales/Athenas (200+ lb / 91+ kg) Looking to lose that spare tire? Ideal weight 200+? Frustrated being a large cyclist in a sport geared for the ultra-light? Learn about the bikes and parts that can take the abuse of a heavier cyclist, how to keep your body going while losing the weight, and get support from others who've been successful.
Clydesdale Wheelset Build
Old 02-18-21, 12:49 AM
aaronmichael
Quoted: 21 Post(s)
Good morning, afternoon, or evening to you,
I'm a manager / mechanic / parts purchaser / wheel builder / etc. at my local bicycle shop....some of you know how that goes. I have a long time customer who would like our shop to custom lace a wheelset for his Bianchi Intenso road bicycle. He weight 250lbs and is currently riding on 20 spoke wheels with 25c tires (as wide as the frame will support). The wheels have multiple cracks in the rim around the nipples on the rear wheel and rusted out bladed (Mavic style) spokes on the front wheel.
My original plan was to build him some traditional 3-cross 32 spoke wheels with a greater focus on a particular high quality rim hoop (given his weight) and less focus on the quality of the hub. However, because of the pandemic, a lot of my suppliers are out of stock on matching items (front hub and rear hub). Albeit very expensive, I found a set of White Industries 28H matching front and rear hubs that we star the wheel build is. My concern is that a 28 spoke wheel wouldn't be enough support for his weight. His riding style is relatively mellow to moderate, he rides far and likes to get out for a good workout but isn't doing any sort of racing, mainly flat ground. I've built plenty of wheels in the past but never for someone of his stature. After some research, the general consensus seemed to be it's less about the spoke count or particular rim and more about the quality of the build that will make it last under this customers weight, or any given weight for that matter.
I'm considering DT Swiss, Velocity, HED, or H Plus Sons for the hoops and White Industries or DT Swiss for the hubs. The bike is equipped with rim brakes so it would be a machined track wheel. Any feedback would be greatly appreciated, thank you so much for reading!
aaronmichael is offline
Old 02-18-21, 01:17 AM
aaronmichael
Quoted: 21 Post(s)
Also, I just realized that because of spoke head clearance, I'd have to build these with a 2x lacing pattern. Also, I'll of course have to build it with double or triple butted spokes to increase durability.
Old 02-18-21, 12:42 PM
ChuckD6421
Bikes: 2013 Trek Domane 5.2; 1986 Cannondale R800
Quoted: 39 Post(s)
Liked 3 Times in 3 Posts
I was only ever a humble wrench in several shops, but I do know well how smaller shops can work. High respect, sir.
Also, just for background, I was once what many would consider "hard core"; made several extended tours (multi-week), commuted by bike exclusively till I was about 26, also competed at Cat. 2 for a couple years. I've always built my own wheels and had excellent success with them. Back then it was GP-4's for racing, Weinmann Concaves for touring.
That was 60 pounds and many moon(cakes) ago.
When I finally made the transition from a freewheel to a freehub 7 years ago, I again went with Velocity rims (Deep V Pro Elite tubulars). By that time I was pushing 240 lbs and closer to 250 on winter rides. This was my second set of Velocitys, 28h. They are solid rims. I ride mostly rural roads in very good condition, lots of hils, Upstate NY. I used DT Swiss bladed aero spokes and some Dura-Ace 7700 hubs I found on eBay. Thousands of miles now and zero issues.
I'm no wheel builder guru, but my observation over the years is that even spoke tension is the key to wheel durability and specifically avoiding those cracked spoke hole issues. The next most critical key to durability is riding them correctly. That means having a good sense for how the bike is ridden over rough areas and where your weight is on it (not to mention in turns as well). If you're gonna spend big bucks on stuff like this you'd better learn how to ride it, and it's different from the city rent-a-bike ebikes.
ChuckD6421 is offline
Old 02-18-21, 12:52 PM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
For rim brakes, you can get Velicity Quill rims with 36 holes.
tyrion is offline
Old 02-18-21, 05:40 PM
tyrion
tyrion's Avatar
Originally Posted by UCantTouchThis
Won't work too well with 28 hole hubs.
Details, details.
tyrion is offline
Old 02-18-21, 08:17 PM
Russ Roth
Quoted: 1088 Post(s)
Liked 1,024 Times in 723 Posts
Are you referring to the spoke angle at the rim and therefore the bend at the nipple? I do find 28h is better 2x.
For the rear wheel I would go single butted 2.2/2.0 spokes like the Wheelsmith HD spokes or something similar. For the front a standard butted spoke or straight spoke is fine and should last quite a bit of time. At 32 or 36h standard double butted is fine.
My opinion on the quill is that it doesn't seem strong enough for a heavy rider to me.
Looking at velocity I'd go with the Dyad, it was strong enough to MTB on its strong enough to road ride on and its what I use on my gravel bike. The Deep V will be more then strong enough but heavy. The fusion as someone else mentioned could also work.
Either hub you suggest is fine, if a more expensive 240 I'd sooner go with Chris King, at the lower end of their line the WI is every bit as good and comes in better colors. You won't go wrong either way.
Russ Roth is offline
Old 02-25-21, 12:56 PM
cbrstar
BMX Connoisseur
cbrstar's Avatar
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times in 69 Posts
One thing to consider is which hub has the widest flanges. It's not just spoke thickness but the angle which the spoke enters the rim. A slightly wider hub will make the wheel a lot more stiff.
cbrstar is offline
Likes For cbrstar:
Old 02-26-21, 12:50 AM
laxpatrick
Bikes: Canyon, Gunnar, Speshes mtb and phat
Quoted: 28 Post(s)
Liked 14 Times in 8 Posts
HED Belgiums have been outstanding IMHO.
laxpatrick is offline
Old 02-28-21, 09:20 PM
tallbikeman
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times in 102 Posts
I ride at and above your customers weight. I like your Velocity rim idea. Deep V's are very stout and very fast. They have very little flex even at my weight. I use 36 hole Chukkar 700c rims on Velo Orange high flange hubs. 3X and bulletproof. I use a pair of Sun CR-18 36 spoke on a 27" wheelset and they have been bulletproof. I bought a Vuelta SL37 hand built 700c clincher wheelset for my "fast" bike. After purchasing and riding this wheelset a while I noticed the spoke count was 16 in back and 12 up front on a deep V aluminum rim. Vuelta uses 2.3mm to 2mm steel bladed spokes. When OP mentioned rusted spokes that points to steel as opposed to stainless steel spokes. Steel spokes are stronger than stainless steel spokes but very much rustier. I have a 1000miles on the Vuelta SL37 wheelset with one spoke tightening after a 100 miles. I believe the SL37 wheelset is 2X. This gives the range of successful wheels I have ridden with very good reliability over the years. I have had spokes pull through a rim but the rim was an MTB rim for disc brakes and very lightly built.
tallbikeman is offline
Old 03-02-21, 04:17 AM
Dirk de Chablis
Dirk de Chablis's Avatar
Bikes: A red one, a white one, a white and red one and a silver one
Quoted: 37 Post(s)
Liked 56 Times in 25 Posts
Can you get Ryde Rims or Ambrosio Rims? I have been riding Miche Wheels (Alturs & SWRs) and Campag Zonda as factory wheels and Record on Ambrosio Exellight 32's and I have been 268lbs and been known to stamp hard on the pedals. Miche have a rider weight limt of 165kgs
Dirk de Chablis is offline
Old 03-07-21, 05:20 PM
mbpletcher
Quoted: 7 Post(s)
Liked 5 Times in 4 Posts
I have asymmetric rims on my road bike. evens out the spoke tension and makes wheels stronger/more durable from what I read
mbpletcher is offline
Old 03-08-21, 04:10 PM
brawlo
brawlo's Avatar
Quoted: 288 Post(s)
Liked 76 Times in 57 Posts
I'd suggest you take another look at that. Unless something's changed, their more durable wheels are only rated to 120kg and the racier ones, to 109kg.
brawlo is offline
Old 03-08-21, 04:40 PM
Dirk de Chablis
Quoted: 37 Post(s)
Who, Miche, Campag or Ambrosio? I'm going by personal experience on what I have ridden and feel, that and Miche test their wheels to the old UCI standard and not the new one that other wheel manufactures cried about because thier wheels kept failing
Old 03-08-21, 05:07 PM
brawlo
brawlo's Avatar
Quoted: 288 Post(s)
Sorry, Miche as per your 165kg claim.
Sure, I too have seen many factory wheels cope under heavier riders, but the fact remains that if you exceed the warranted weight limit you have zero recourse in a failure situation. Better to go for something purpose built to cope and backed up by a builder IMO. FWIW my current wheelset was built by prowheelbuilder and still going strong. My MTB wheels I built myself, and my next set of road wheels I will also build myself
brawlo is offline
Old 03-14-21, 08:02 PM
Moisture
Drip, Drip.
Moisture's Avatar
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times in 163 Posts
Someone correct me if I'm wrong, but you absolutely can build a damn strong wheel with less than 36 spokes.
Moisture is offline
Old 03-14-21, 11:13 PM
brawlo
brawlo's Avatar
Quoted: 288 Post(s)
100% not wrong. You just need the bits built strong enough and in the right way, basically in reference to the rim. The problem is that rims generally aren't built with heavyweights in mind. What we need is a lightweight rim with extra material at the spoke holes to survive high spoke tension. Also a problem is that the extra weight at the rim feels heavy. When I was more seriously racing at ~265lb I had a set of Shimano RS81 C50s 16F/21R. They were nice wheels!
brawlo is offline
