Does anyone still make a bottom bracket dynamo?
I’m trying to help a friend power some lights on the cheap. Light theft is a big problem here, so I want to avoild a battery powered removable light. It seems like a bottom bracket dynamo might be the best route since building a new wheel with a hub dynamo will be expensive. She’s also small, so keeping her modern, light weight, 20 spoke wheel is better than throwing on a hearty 36 spoke touring wheel with hub dynamo. The only problem I’m having is I can’t seem to find a BB dynamo... Are they still made?
No longer active
Quoted: 89 Post(s)
Liked 6 Times
Do you mean like a 'drag dynamo;' one that attaches behind the BB shell, with a roller that drags against the tire? Or one that's wholly contained inside the BB shell & generates power directly from pedaling?
If the former, I'm pretty sure Sanyo still makes one; and I'd swear I recently saw one made by Axa, but I'm not totally sure about that (it's been a few years & my memory is a tad fuzzy; I might be thinking of an NOS vintage unit).
I was exploring these for a while myself as one of my 650b bikes (my Panasonic) has a brazed-in bracket for mounting a BB dynamo.
They stopped making the BB dynamos a while back. Sanyo was the most well known. Soubitez made one too. There's a few hokey bolt on modern generator gizmos available if you look for them. Or you could try to buy a vintage one. They weren't that great anyway. Tended to break after a while.
If you don't want to spend a lot of money, or even if you do, IMO the best choice is a modern LED battery light. I love my cygolite. They unclip usually. Have your friend take it with her when the bike is locked.
Likes For Salamandrine:
Quoted: 659 Post(s)
Liked 7 Times
The Sanyo and Soubitez ones still show up on eBay. I.e. :
https://www.ebay.com/itm/NEW-Soubite....c100011.m1850
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
In addition to the Sanyo and Soubitez ones, there is one made by Union. The Union one may be the most recent, but I don't know when it was made. It's pretty neat since it was made to be cable operated; you turn it on/off with a control lever on the seat tube. It's also pretty easy to attach to a bike. I don't know how tough they are; it appears to be made of plastic or resin, but I have not seen one get damaged.
The Soubitez one is robust and well made, but I dislike the way it mounts to the bike. I have one that wouldn't fit I the bike I wanted to use it on; on other bikes it is prone to alignment problems. Worth a try if you can find one.
I have several of the Sanyo ones, and I cannot recommend them. They were nicely made, but there is something wrong with the bearing, and all the ones in my possession make an ugly squealing noise. They may be fixable. (Anyone want to try? Send me a message).
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 532 Times
My 1984 touring bike was wired for a BB generator but had none when I purchased it around year 2000. All I could find was a NOS Soubitez. Later I picked up a NOS Sanyo thinking the Soubitez would probably fail. After a lot of use, French unit is still going strong though, so I agree they are robust. Don
Quoted: 7351 Post(s)
Liked 2,479 Times
I got one of the Sanyo dynamos at a bike swap meet for about $10. I installed it on my wife's bike for her. I want her to have lights even though she doesn't intend to ride this bike at night. It suits the purpose well. We found ourselves riding at sunset time once, so she has used the dynamo once. It creates more drag than a hub dynamo but less than a sidewall dynamo. It was pretty easy to install. If I remember right, it has only one wire coming out of it and uses the frame as ground. I had to run a ground wire from the bottle cage bolt to the headlight.
I hear that the roller can lose traction with the tire when it's wet. The chances of my wife riding on a rainy night are small enough to take that risk. I hear the problem can be mitigated by gluing sandpaper or skateboard paper to the roller, and I might try that only because it's an interesting challenge.
@rhm, were you unsuccessful at forcing oil into the bearing(s)?
Likes For noglider:
multimodal commuter
Liked 574 Times
Liked 2,479 Times
Don't forget marinading it with a little salt and lemon juice. Is pickling a technician's term, or did you just adopt it? I love it.
Quoted: 1858 Post(s)
Liked 664 Times
I don't know if the OP has ever perused the iBob list (now a Google Group, but I think you'll get a very erudite discussion about that.
Liked 664 Times
I don't know if the OP has ever perused the iBob list (now a Google Group), but I think you'll get a very erudite discussion about that.
Liked 2,479 Times
No, I love leaving my lights bolted onto my bike. I lock my bike up sometimes, and the only trouble I had was someone without a wrench tried to remove it by bending it. I bent the bracket back into the original shape, and the light was back in business. Funny, the thieves carry cable cutters with them but no wrenches.
They were discontinued because the mounting position puts them in line for all the worst gunch the road can throw at a bike. Even hard-working long-suffering bottom bracket bearings are not so directly in the line of fire. Building one with fully shielded bearings, as opposed to the little dust covers on most cartridge bearings, would be cost prohibitive and heavy. Half the potential market for these is also using fenders. Look at the photo above and imagine what a fender would do.
Current battery lights are really good.
Passista
Quoted: 868 Post(s)
Liked 721 Times
Why not a bottle dynamo? They are much maligned but they are simple, cheap and work OK if they are correctly aligned and you don't ride too fast (like under 24kph/15mph). I hear there are millions of them still in use in Europe.
Liked 2,479 Times
Except that yes, battery lights are good, dynamos offer a convenience that's hard to beat.
Likes For noglider:
Quoted: 467 Post(s)
Liked 532 Times
"I hear that the roller can lose traction with the tire when it's wet"
I heard this also, but never experienced it with my Soubitez unit, despite daily use, sometimes for weeks, during our wet, NW Winters. So, another plus for the French design. Don
The old rule was that they were suited for heavier tires only, because they chew up the sidewalls. Good for gumwalls but not skinwalls. That's why the BB dynamos became popular. They could be used on lightweight higher end bikes. BITD most people with racing bikes had to make do with a wonder light. I did. By the later part of the 80s and 90s, expensive battery systems were what most enthusiasts used if they needed lighting.
Liked 2,479 Times
I used a sidewall dynamo with tubular tires, though not extensively. Maybe it would have chewed up my sidewalls, but who knows.
Passista
Quoted: 868 Post(s)
Liked 721 Times
You could also use a rubber roller on the dynamo to save the tire.
Squeaky sanyo
while the bb dynamo provides much more drag than a hub one, it provides zero drag when not engaged which for me is most of the time
Quoted: 378 Post(s)
Liked 1,410 Times
"Light theft is a big problem here, so I want to avoild a battery powered removable light."
All of mine are removable. That, perhaps, would change if I commuted by bike and not tele---. My '59 Sports uses the front dyno, and it's not something I'd depend on to see. I have had two bottle-type, and I didn't like either one, but they worked, valued as much for the taillight as the headlight, because for me, being seen is the goal.
"I’m trying to help a friend power some lights on the cheap."
The inevitable conflict always comes with most devices when performance is required on the cheap.
We want to play, not to pay. Human nature.
i had a squeaky Sanyo unit(mine was just old but really hadn’t had a lot of use) but fixed it. First tried putting thin oil through what looked like the seals to the bearings but didn’t work, so bit the bullet and took the assembly apart, take photos, have to get through the release/engage mechanism first. Put some grease in the end cap, it has a strange screw there that looks like it s to put lubricant in couldn’t get to the bearing inside the dynamo, reassembled and all is good,but possibly done only 20 km on it so far.
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
I have a soubitez bb dynamo. It works better than a sidewall unit but i would build a wheel around a cheap ebay hub dynamo before i would regularly use the soubitez.
and if you ride the bike for exercise, the extra drag from the bb dynamo is just part of the fun!, and of course there is no increase in rotational inertia andtranslational inertia of front wheel or drag when it is not being used.
Sometimes on pedals
Quoted: 5 Post(s)
I was really interested in bottom bracket dynamos. But they have not been available here.
Bottle dynamos suck. One of the most evil things to put on a child's bike is a bottle dynamo.
I suppose hub dynamos are quite obvious nowadays. But, what if you wanted to combine a new ceramic rim with a new hub dynamo? Mission not possiblé.
But, there are still some options. Reelight NOVA contactless rim dynamo looks interesting.
