Which Garmin?
Which Garmin?
For years I’ve ridden with no cyclometer on my road bike. I ride mostly solo, and being in WV, I generally ride back roads. So I’m really liking Garmin’s rear looking radar, the Varia. Now I need to find a Garmin to go with it.
I’m looking at the Garmin Edge 830 and the Edge 1030. Because the 1030 is on sale, both are priced at $400. Normally I would go with the higher end unit considering they are the same price. But I see quite a bit more negative reviews on the 1030. Also, I know the 830 is a fairly recent product release, not sure how long the 1030 has been out there. I suspect it’s fairly dated, and that’s why it’s on sale. Any input that would help me make a decision would be most appreciated.
Quoted: 941 Post(s)
Liked 319 Times
You might consider the Wahoo Bolt. I recently acquired a Varia, it pairs with the Bolt and works very well. The Bolt is available for $200ish.
Quoted: 878 Post(s)
Liked 726 Times
Second the Bolt. Regular Elemnt if you want a larger screen. I've been afflicted by my Edge flaking out and not properly reporting Varia readings in the middle of rides, would not recommend an Edge if the Varia is important as it's a well-known and unfixed problem where the only workaround is to disable the Bluetooth phone connection, meaning losing LiveTrack (which in turn is something that Garmin breaks every so often... you can see where this is going ).
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 191 Times
I have a 520 plus. It's my first cycle-specific garmin - I've used the cycle function in my running watches up until now.
Quoted: 941 Post(s)
Liked 319 Times
A question for other Varia users. I've used mine a couple times now. It never missed a vehicle or multiple vehicles. I've learned to recognize the audible difference between the approaching signal and the all-clear. However, there is one I thought might be associated with a vehicle approaching from say, a side street. It didn't happen that often, but does the Varia defect laterally approaching vehicles?
Love my Varia, btw.
FWIW, Edge 530 user here. If the 830 is even close you'll probably love it. Display easy to read. Works seamlessly with the Varia, of course, and no problems with phone/BT dropping out which I've read is more of an issue with strength of cell signal. Prior computer was a 520 and it worked fine, too.
Garmin states that all of the features of the 830 will be available on the 1030 through firmware upgrades - I don't know where they are on releasing that.
Likes For tntyz:
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
Another happy Varia user. It's paired to my 520Plus. No issues. It has *NEVER* failed to alert me to a car, truck, or motorcycle, and I swear it seems to alert slightly differently if a vehicle is overtaking me really fast vs a bit more slowly. (Might need to read up on that. Could be my imagination.) As long as I remember to charge it up every few rides I have had nothing but success with my Varia/Edge 520Plus combo. So far.
Bikes: Jamis renegade, surly big dummy, giant talon 29er
Quoted: 62 Post(s)
Liked 42 Times
I have been using a Lezyne Mega XL for about a year now and love it. The price is great and so are the features. I dont need a super crazy color display and the battery life is great. If there are any other lezyne users do you know if the varia is compatible with lezyne units?
Quoted: 878 Post(s)
Liked 726 Times
Notice how it took them a year from reported issues to claim they addressed it in a firmware update. That's not even as fast as their turnaround for fixing LiveTrack between the times they break it.
Quoted: 4260 Post(s)
Liked 1,364 Times
It seems the 830, even being new, didn't have the same sorts of issues the 1030 had early on.
The bigger screen on the 1030 is better if navigation is important. The 830 has a faster processor (never a bad thing) but the 1030 doesn't seem slow to me.
I don't think you'd go wrong with either (other than the advantage of the bigger screen on the 1030).
Quoted: 3242 Post(s)
Liked 2,090 Times
Agree with NJKayaker, the 1030 has been a reliable unit for a while now and it’s a good price currently at $399. I’d take a 1030 over a Wahoo Elemnt Roam at $380, Garmin has much better maps. 1030 is rated at 20 hrs, Roam at 17. My run time of my 1030 varies at 5-7% an hr after 2 years of use, so easily seeing 15-20 hrs.
If you want something smaller, the Garmin 520 Plus is also on sale at $200.
Both on sale at clevertraining.com
Bikes: A few older US made Cannondales, a modern Soma Saga (no longer made, alas!), and one gifted crabon Specialized. Never enough.
Quoted: 45 Post(s)
Liked 60 Times
Another vote for the 1030, especially if you have less than ideal vision. The big screen makes a huge difference for me. An improvement over the 1000. Works fine with the Varia for me, too.
Liked 1,364 Times
Unless you don’t care about navigation at all, the 530 for $100 more might make more sense.
The 830 is much better than the 820.
Since the 1030 received the update that brings along the best features of the 830 (especially ClimbPro), the deciding factor should be screen size. If you like to have more than 8 fields on one screen, or spend a lot of time looking at your map screen, or have failing eyesight (like me), then the 1030 may be the better choice; otherwise, get the 830 because it's the latest and greatest.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 272 Post(s)
Liked 448 Times
I have a 1030 and Varia. Mine with the older screen was just replaced due to the blue halo starting to appeared. I looked at the Wahoo computers but they did not have the features I wanted. Also I wanted to connect and mange it with BaseCamp. I don;t want to rely on an internet connection and have a tablet. It works dragging and dropping information. The 1030 does a lot which makes it complicated. I like having profiles for indoor, mountain biking and road bike. Just wish the sensors could be tailored to the profiles. The maps are good for placed I have not ridden. Some mountain bike trails show up.
I used an Edge 1000 for a couple years and liked it so well I got an Edge 1030 about 6 mo ago. They have multiple screens with up to 10 readouts per screen; it works great with power meters so you have instantaneous data and the screens can be changed by swiping a finger left to right or right to left. I have Di2 and there are buttons on the shifters that allow you to change screens on the Garmin.
Quoted: 800 Post(s)
Liked 512 Times
I've had the 520 for three years now - going on four - and have had zero issues with it. Perfect little computer. My only complaint is that the battery life of the 520 when paired with the Varia is poor. This might be due to how I have the Varia setup on the 520. The screen lights up every time car passes me. On a busy city street there are cars passing me all the time, so the system is always lighting up.
I plan on change the screen timeout to a much shorter time to see if that helps.
That very small issue aside, I have no problem recommending the 520 (which is no longer made I think).
Mrs. NoWhammies just started riding with the 530. After two rides she thinks is great. Clear, large bright screen. Wireless syncing. She's happy.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I just switched to the 1030 and its really an impressive unit. I had a 520. The 520 was an excellent unit for me for years! I would recommend either. Now that I have a 1030 I would never go to something smaller. At $400 its a good value for the computer you get.
You might want to check out the Garmin Edge Explore. It's just a tiny bit smaller than the 1030, but quite a bit bigger than the 530's and it's only around $250.
The main things it's missing compared to the 1030 are a barometer, powermeter compatibility, and workouts, things you may not be interested in from the sounds of things.
I have a Garmin 530 with the Varia and it seems to work great, although I've only been using the two for a couple months. I considered the 830 at the time I purchased my 530 and I read quite a few reviews that said the touch screen can be a problem if you wear gloves. I live in a cold and rainy climate 6-8 months of the year, so my gloves are almost always full fingered and not necessarily touch screen friendly.
