What is faster: KENT GZR700 Road Bike vs Trek FX2
Bikes: Trek, Schwinn, Huffy
Quoted: 101 Post(s)
I have seen some well reviewed very cheap road bikes. This is an all steel one by Kent.
With my budget if I got a road bike I could only afford a very cheap one - Kent one is $189.00 on Amazon
I have figured if that is all I can afford I am better just sticking with my FX 2 for a few years till my financial situation improves, unless the Kent would ride better on paved surfaces and roads than my hybrid. I do live in an area with a lot of small hills. The Hybrid is Aluminum this road bike is steel..
Thoughts?
KENT GZR700 Road Bike - steel road bike
would this ride at same speed as my Trek FX2 Hybrid or faster?With my budget if I got a road bike I could only afford a very cheap one - Kent one is $189.00 on Amazon
Thoughts?
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Stick with the FX2 or buy something better used. That Kent is budget everything.
Likes For znomit:
If you’re looking to get more speed, upgrade that engine - healthy diet/lifestyle, plenty of training miles. From there, look to optimize your position on the bike. Doing those 2 things will net you more than any $10,000 bike will, and guess what - they’re not relatively budget friendly!
Likes For yamsyamsyams:
Quoted: 101 Post(s)
Yeah I will probably just stick with the hybrid and not bother with a cheap road bike unless I can find a used schwinn varsity that is in good shape.
Sunshine
Quoted: 10969 Post(s)
Liked 7,495 Times
Quoted: 101 Post(s)
...because I really know nothing about what makes a bike faster over another one and I was just guessing?
I was guessing because the varsity has much thinner tires and has the bent handlebars allowing the rider to assume a more hunched over power position that let you put more your legs and hips into cycling that this would equate to faster performance, but that was a guess.
on my Trek and in the gym on the stationary bike when I lean forward I seem to have more strength in my legs and hips to push the pedals downs at a faster pedal rotation speed in higher gears, pedaling seems easier for me in that position. On my trek I don't have any handlebars for the hunched over position so I just rest my elbows on the bike.
I thought the thinner the tires are = the faster the bike?
...and I thought the Varsity would be better than the Kent? If I did get the varsity since I am a smaller rider... probably would need size 117 17" or Junior 24" varsity...
I am only guessing?
I am only guessing?
All things being equal you are generally correct
But that Kent is so much lower quality than your trek that it would most likely be slower than your trek
If you were talking about a roadbike of equivalent quality to your hybrid then things would be different
Bikes: 2005 Seven Odonata (DuraAce /Reynolds),1983 Trek 950 (Mavic/Suntour/Regina), 1986 Stumpjumper Shimano/Suntour/Regina), 1986 MASI 3V, (Campy/Mavic/Regina) 1995 Schwinn LeTour (Suntour/Wienmann/Phil/Shimano/Regina): All Brooks Saddles
Quoted: 25 Post(s)
Thoughts?
Thoughts?
Quoted: 645 Post(s)
Liked 797 Times
The drop bars on the Kent will allow you the attain a more aero position, which might improve your efficiency at speed, but the bike itself seems pretty crappy - 31 lb, dubious reliability - the reviews on Amazon are pretty bad - there’s a real risk that a year from now you’ll have a $189 bike in need of repair but not worth repairing
