puch royal force bottom bracket
Hey guys,
I've bought a Puch Royal Force frame recently. Do you know what threads they used for bottom brackets? I've tried a Shimano 35xp1 (which seems to be french) and it doesn't work.
Many thanks!
Many thanks!
Quoted: 3814 Post(s)
Liked 3,345 Times
Puch builds to BSC/ISO standard ("English")
one thing to be aware of on some of the lower models is that 26.0mm steerers were employed which means that headsets for such frames are special
the 26.0mm steerer is sometimes referred to as "Austrian size" in the world of bicycle jargon
it is not found on the upper models
Likes For juvela:
juvela thank you for this useful info
From what i've seen, Royal Force seems to be their high-end model... maybe i'm lucky
So, should i look for a 1.37x24T bottom bracket?
Liked 3,345 Times
ja machen
