How do you keep your water cold on hot days?
Quoted: 20810 Post(s)
Liked 9,456 Times
Liked 6 Times
Ice cubes help. If your bike has a trunk bag or pannier, you can also stash your extra bottle(s) in them with a sock for extra insulation. Using a hydration pack will also work.
Alternately, you can rebuild your front wheel with a dynohub and build a custom peltier solid-state cooler that runs on 6-volt AC.
Liked 9,456 Times
Liked 6 Times
There are some reasonably light dynohubs these days, like the Shimano DH-3N80. If it seems too heavy, you're probably riding too fast and causing the mass to increase, which can also heat up your water due to the air friction. Keep your speed below 0.25x the speed of light and see how that goes.
Bikes: 2013 orca
Artificial Member
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Quoted: 6767 Post(s)
Liked 5,479 Times
Throw the stick!!!!
I keep it in my fridge, when I get thirsty I get off the couch and get a drink.
I may be fat but I'm slow enough to make up for it.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Buy it at convenience stores
Bikes: 2012 Trek Madone 5.2
+1 for freezing the bottles. I use those disposable 500ml. water bottles, freeze them about 1/3 full, then fill them with cold water before the ride. I usually bring 3-4 along for a 3-4 hour ride, then throw them out as I finish them.
Bikes: Trek 1.2 & Single Speed Rain Bike
I got mine off someones front lawn. Works great, I might add a stove on the other side to balance things out.
This might be better
Just Keep Pedaling
Bikes: 99 Schwinn Mesa GS MTB, 15 Trek Domane 5.9 Dura-Ace, 17 Trek Emonda SL6 Pro & 18 Bianchi Vigorelli
Quoted: 251 Post(s)
Liked 67 Times
"mr Scrap, how do you get the ice in the bottle?"
Bikes: 2 TiSports and a Ho Ko E Koo
Quoted: 54 Post(s)
I fill my Polar insulated bottles 3/4 full with water and freeze them. I also add a little salt to my water whenever I ride. I usually carry one frozen insulated bottle and one regular bottle.
SuperGimp
Camelbak podium chill.
Polar keeps your water cold but you can't get it out.
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
Haven't tried this, but saw a guy had put a sock over his bottles in the cages. He said it kept the hot air off them better.
As the temps rise down here, I'm going to try freezing mine half full, then top off to ride.
Quoted: 663 Post(s)
Liked 496 Times
The sock idea would work. First is freezing a nearly full insulated water bottle - then I use old fleece mittens over bottle and cage. It will stay cold for 4-5 hours in 85F temps.
Bikes: Specialized Tri Cross; Specialized Tarmac SL3
+1, this is what I do, and most of the time there's still some ice in the bottle when I get home.
Yesterday I filled my bottles about 75% full with a mix of water/G2. I'll top them off with water before I leave in a bit so I have something to drink when I begin. Usually this lasts through the ride. (should work today, it is mid-60s now and should be around 80 when I finish).
In the worst of the summer the amount of ice left will be quite minimal. Not much to be done when the overnight low is 95.
