Chain maintenance
Old 06-08-19, 07:36 PM
boggy
boggy's Avatar
Bikes: 2007 Novara Aspen, 2011 Fuji SST 2.0, 2018 Electra Townie Commute GO! 8i
Quoted: 28 Post(s)
Liked 3 Times in 1 Post
Chain maintenance
Just have a question about regular chain maintenance, and wondering if I am doing it right, or too much - any input would be appreciated.
I commute to work 20 miles one way daily, so I ride around 200 miles per weak on the city streets. It's not as tough as it sounds, since I use electrical assist bike, but it's still pretty hard wear on the drivetrain.
I clean the chain once a week with Finish Line grunge brush and bike chain degreaser, and after drying chain clean with towels I apply 3-in-one oil to each pin in the chain, removing excess oil with clean towels. 3-in-one oil is [much] cheaper than purpose bike oil, and it does have bicycle icon and "long lasting" verbiage on the can - which makes me believe it's an okay oil to use.
The chain is super smooth and makes no noise whatsoever first couple of days after that, and by the end of the week I can hear something that resembles normal drivetrain noises, but I never heard squeaking in between chain cleaning.
Is this all normal, or I am doing it way too often? Does using non-purpose oil making it all worse, would it be cheaper to use some sort of professional oil but less often?
boggy is offline
Old 06-08-19, 07:38 PM
wgscott
Occam's Rotor
wgscott's Avatar
Quoted: 2366 Post(s)
Liked 357 Times in 215 Posts
Why not make your life clean and easy and use wax, or some wax-based lubricant like Squirt?
wgscott is offline
Old 06-08-19, 08:07 PM
Jon T
Bikes: '84 Peugeot PH10LE
Quoted: 391 Post(s)
Liked 42 Times in 30 Posts
I use White Lightning dry chain lube and like it a LOT. Since it is dry, it doesn't pick up all the road dirt and actually stays clean.
Jon
Jon T is offline
Old 06-08-19, 08:09 PM
Bigbus
Bigbus's Avatar
Bikes: In Flux
Quoted: 125 Post(s)
Liked 41 Times in 30 Posts
I'm a proponent of wax for lots of reasons, the main one being it doesn't wash off in the rain and mud and the second being ease of application. Cleaning is easy if you use a warm solution to make the wax melt. Oil is better than nothing unless you ask my dad. He believes oil just attracts dirt which is worse than metal on metal. Go figure. We've been having that discussion for more than 50 years and it never gets old. But then neither does he, or so he would have you believe.
Bigbus is offline
Old 06-08-19, 08:22 PM
wgscott
Occam's Rotor
wgscott's Avatar
Your dad is right.
wgscott is offline
Old 06-09-19, 09:12 PM
NoWhammies
NoWhammies's Avatar
Quoted: 465 Post(s)
Liked 91 Times in 61 Posts
Do you need to prep the chain any special way before applying White Lightning? I've heard good things about it (I currently use Pro Link) and am thinking of switching and giving White Lightening a try. Thanks.
NoWhammies is offline
Old 06-10-19, 10:57 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6964 Post(s)
Liked 293 Times in 234 Posts
buy an extra chain, swap them on saturday, dunk/soak *them clean in solvent ,
and be ready to do it again next saturday..
*or wax pot.
Probably go through a cassette and a pair of chains at least every 6 months , I'd guess..
Given that's 5200 miles ..
YMMV...
Maybe one of those plastic tank chain-cleaners, every few days..
wipe off the outside, oil there does not matter, under the rollers is what wears..
fietsbob is offline
Old 06-10-19, 05:17 PM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2591 Post(s)
Liked 473 Times in 341 Posts
The answer to all these questions is whether your chain lasts long enough to make it worth it.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 06-10-19, 05:38 PM
caloso
caloso's Avatar
Quoted: 2085 Post(s)
Liked 551 Times in 306 Posts
That seems like a lot of work. About once a week I dribble lube (I like Pro-Link Gold personally) on the chain as I turn the pedals backwards. Then I take an old tshirt and grab the chain as I continue to turn the pedals backwards. Then I go for a ride.
caloso is offline
Old 06-10-19, 09:51 PM
Jon T
Quoted: 391 Post(s)
All I did was clean it using the Park Tool chain cleaner and some Mr. Clean degreaser. After it dried I just applied the White Lightning as per the instructions. It's clean and noise-free.
Jon
Jon T is offline
Old 06-10-19, 10:10 PM
NoWhammies
NoWhammies's Avatar
Quoted: 465 Post(s)
@Jon T Thanks.
@caloso Are you cleaning your chain at all before re-applying the Pro Link? Or are you just applying the lube over the existing (dirty?) chain? I notice my chain turning black and I clean my chain before re-applying the Pro Link. This takes a lot of work though, so I'm curious about your method. Thank you.
Old 06-10-19, 10:28 PM
caloso
caloso's Avatar
@Jon T Thanks.
Just lube and wipe.
caloso is offline
Old 06-11-19, 07:02 AM
Kapusta
Cyclochondriac
Quoted: 1153 Post(s)
Liked 245 Times in 162 Posts
More work than I like to do, but there is certainly no harm in it, and the results are probably as good as you ate going to get in terms of drivetrain wear.
Kapusta is online now
Old 06-11-19, 07:17 AM
TimothyH
- Soli Deo Gloria -
Quoted: 6824 Post(s)
Liked 655 Times in 412 Posts
The contaminated degreaser needs to be treated.
I hope you are collecting it and taking it somewhere like the county dump for recycling.
-Tim-
TimothyH is offline
Old 06-11-19, 11:02 AM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1298 Post(s)
Liked 152 Times in 100 Posts
Here's a data point for you:
I don't know the last time that I serviced my chain. I certainly don't keep records of stuff like that. I run it until it starts to make noise. Then I wipe it as clean as I can with a spray of WD40 on a rag. When it dries, I put the smallest bit of lube I can on each link, wait for it to set in and try to wipe it all off until I get bored with the process. I used to do that process pretty much weekly. Since my benign neglect days, I really haven't seen any difference.
The same goes with tire pressures but I know when I last topped up my tires. It was May 1st before we left for the spring recumbent rally in Xenia.
Like I say, it's just a data point. It's all that I do, and our trikes continue to function well.
Retro Grouch is offline
Old 06-11-19, 11:11 AM
I-Like-To-Bike
Been Around Awhile
I-Like-To-Bike's Avatar
Bikes: Vaterland and Ragazzi
Quoted: 11 Post(s)
Liked 270 Times in 168 Posts
Way, way too OC-like for my taste, but apparently seems close to normal for some of the enthusiasts of BF. No harm in it though, if you enjoy spending your time on that kind of activity..
I get satisfactory chain wear and smoothness with an occasional (once month/200 miles or so) spraying from a can of silicone spray
I-Like-To-Bike is offline
Old 06-11-19, 12:35 PM
Kedosto
Ambulophobic
Quoted: 491 Post(s)
Liked 201 Times in 121 Posts
I'm doing about 150/week so we're doing about the same mileage and here's what I do...
Once a week I wipe down the dirty chain with a rag until I'm satisfied I got as much as I could.
Add Finish Line Dry lube, link-by-link and work it in by spinning the cranks backwards.
About once a month or month and a half I clean the chain using a Park Tool chain scrubber filled with mineral spirits. Wipe it as dry as I can and start over again with the Finish Line Dry.
I wish I could use White Lightning wax lube. If you're ok with the black dandruff the chain sheds with White Lightning then IMO that's the way to go. It's easy to apply and with a simple wipe down you can get the crud off but with the way it works, most of the crud falls off on its own (that's the dandruff). I bring my commuter into my office on the second floor of a hospital and it's the black flaky dandruff that kills the deal for me. There's no arguing the fact that wax based lubes give the cleanest running chains. I don't think wax based lubes last as long as oil based, but with the ease of use I would be happy to simply apply a bit more often.
-Kedosto
Kedosto is offline
Old 06-13-19, 06:33 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 503 Post(s)
Liked 171 Times in 104 Posts
A few years ago I switched from a molten wax dip to Chain-L. I liked the cleanness of the wax but it lasted like 3 days before the chain got noisy, especially if I had a wet ride. Chain-L lasts at least 1,000 miles before I need to relube. It is a thick, sticky oil that contains no solvent. After I apply a drop per link and allow it to migrate into the chain, I wipe the outside clean, repeating the wiping every day every few days until I relube. The chain stays fairly clean. I used remove a chain and clean it with solvents; however I found that with Chain-L it is not functionally necessary to do this. Just wipe often, re-lube, when you start hearing a bit of noise, and replace the chain when it's worn. Easy peasy, and no messing with solvents.
Good luck whatever you do or use.
Moe Zhoost is offline
Old 06-13-19, 11:39 AM
starchase
starchase's Avatar
Bikes: 1992 Giant Farrago; 2011 KHS, TC-150
Quoted: 7 Post(s)
Clean the chain??? What a novel idea!
starchase is offline
trevor1968
Bicycle Mechanics
65
08-18-15 08:28 AM
Jed19
Bicycle Mechanics
52
05-14-15 09:51 AM
coolkid_cody
Bicycle Mechanics
50
01-04-14 08:29 AM
ckaspar
Bicycle Mechanics
15
03-19-12 09:02 AM
The Scotsman
Bicycle Mechanics
18
05-14-10 01:48 AM
