Bar-End Shifter - Turn 8 into 9 speed?
Does anyone know if it's possible to use the base of 8sp Shimano bar-ends and get 9sp levers in order to convert to 9sp? I have 8sp shifters, but need 9sp. 9sp are expensive, so it would be nice if I could convert the 8sp to 9sp.
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
The levers themselves are not what determines the indexing, it is the expensive pieces inside the housing of the shifter that the lever connects to that does the indexing. There is no inexpensive way of doing indexed nine speed.
You could do friction mode if your shifters support it. I run my 7 speed Deore XT thumbies in friction mode with an 8 speed cassette.
Quoted: 263 Post(s)
Liked 9 Times
Are you saying you have 9 speed shifters and want to put them on 8 speed bar end mounts?
I think it would work - give it a try if you already have them.
9 speed bar ends will run somewhere from $65 to $75.
I don't have the 9sp shifters yet, or I would just try and see if it would work. I would by some 9sp down-tube shifters for ~$40 and swap them. I can't seem to find 9sp bar-ends for less than $85ish.
the 9 detents are in the lever ,but Shimano is not selling loose parts so go look on Ebay.
Whats wrong with 8 ?. I toured dozens of countries with a 13~34t 6 speed freewheel , No index shifting,
IMO its your gear ratios that matter not the cog count on the back wheel.
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
If you aren't already committed to 9, Nashbar has Dura Ace 10 speed bar ends for $49.99.
Constant tinkerer
There are a few options listed in the order I would do them in:
1. Get an 8-speed cassette and chain.
2. Get 9-speed bar-end shifters or throw some 9-speed DT shifters on your pods.
3. Run whatever you want in friction mode.
If you decide to dump your 8S bar end shifters, I'm also in Madison and would love another pair!
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Assuming you can even find the pieces (and make them work) you will then have a bunch of useless 8-speed parts.
Find the 9-speed ones on ebay and sell your 8-speeds there as well...
Today, I believe my jurisdiction ends here...
Bikes: 2013 Rivendell Sam, 1996 Bianchi Milano, 1994 Trek 820
Quoted: 13 Post(s)
Liked 8 Times
Another option that doesn't cost a thing is turning the selector on your 8spd bar ends from SIS to friction. Then they will shift your 9 spd cassette.... Shimano 9 spd bar end levers aren't sold separately from the mounts, although Dura Ace 9 spd downtube levers are available and could probably be put on your 8 spd bar end mounts. Price is similar to the 9 spd bar ends though, so no savings there.
Constant tinkerer
Quoted: 273 Post(s)
Liked 10 Times
I was referring to the guts of the 8-speed shifters, not the shifters themselves; not much demand for shifter parts...
I have an 8sp chain and cassette on my current touring bike. I've decided that it's not quite right for me. But anywho, I also have Ultegra/600 tri-color front and rear derailers that go with these shifters if you're interested, along with the chain/spare chain pins and 2 cassettes(one more aggressive road gearing, one for touring) if you're interested in the whole 8sp bunch. I could definitely use the cash to help with this upgrade to 9/10sp. PM me if you're interested and shoot me an offer, or if you want I can do some value research and try to come up with a fair asking price on whatever you're interested in.
If I went to 10sp bar-end shifters, chain, and cassette, I could still use my 9sp XT/LX derailers, correct?
Constant tinkerer
Quoted: 263 Post(s)
Liked 9 Times
Bar end's are friction front anyways so it would work fine. Actually, I am running more or less that setup - Dura Ace 10 Speed bar ends with 9 speed SLX rear derailleur
