Carbon wheel advantages over aluminium?
Hi there, I have recently been looking at a set of relatively affordable carbon wheels that are available in both 45 and 55mm profiles. They would certainly both look nice on my bike but the 45 version weighs 1650 grams or so and the 55mm 100 grams more.
That’s not insanely heavy but I already have a set of decent aluminium wheels with a 32mm profile that weigh in at around 1450 grams. So I am in doubt if the carbon wheels would offer any advantage over the alu ones. Given that, at least in the case of the 45mm carbon rims, the profile isn’t that much deeper, would those wheels offer any significant advantages over the aluminium wheels I already have? Or would you, due to the heavier weight, even expect them to perform worse? Any insight will be much appreciated
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
Bikes: Basso Luguna, Fuji Nevada
Quoted: 4261 Post(s)
This was posted in a recent thread where I posed a similar question. The aero advantage is more important that weight from these test.
FLO Cycling - The Great Debate - Aero vs. Weight
Sorry, just realizing I probably asked the question in the wrong way. This is probably better: If you have two wheels with the same rim profile and weight, one is carbon, the other aluminium, would the carbon wheel offer any advantage over the alu wheel? Would it be more comfortable, stiffer or somehow 'quicker' despite same weight/profile?
Quoted: 6556 Post(s)
Liked 58 Times
Bikes: Jamis Sputnik
CFRP has a higher stiffness:weight ratio and thus with proper engineering should give a wheel with a higher stiffness:weight ratio. Keep in mind that geometry plays as important of a role in stiffness as material, though.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
By getting to the coffee shop 12 seconds faster or slower than before
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
Super Moderator
Liked 927 Times
I use 50mm carbon tubulars for racing. I ride on basic aluminum rims the other 99.9 % of the time.
Don't ask me which aluminum rims, I have no idea.
Have not felt the need to spend big bucks on wheels. Good tires are worth it though.
You get carbon wheels for aero, lightweight or both.
If you are just as aero and same weight with alloy, than enjoy the better braking and durability of alloy without lightening your wallet by a K.
Thanks for your insight, guys! You've pretty much confirmed what I thought. Carbon for carbon's sake doesn't do it. I usually ride on hilly terrain and sometimes on proper mountain passes, so a lightweight wheelset with a bit of profile does make sense for me. A Carbon upgrade would only make sense if I get a deeper profile at the same weight or the same profile at a lower weight and that would cost me a lot of money, not worth it
Bikes: '11 Merlin Extralight, '98 Dean Castanza, '89 Schwinn Prologue
Quoted: 19 Post(s)
Bikes: Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
Quoted: 126 Post(s)
Liked 55 Times
To the OP, take a look at some Boyd carbon wheels. Well priced and also not nearly has heavy as you mentioned.
In my experience with carbon wheels (Boyd 44 carbon tubulars), they are very stiff and climb quite well, weighing in the 1400-something range - the clinchers are a little bit more heavy. The wide rim width is a benefit. Running 700 x 25 tubular tires at lower pressure (85psi) makes for a very compliant ride and lower rolling resistance than say 700 x 23 at 110psi. They do not get blown around in the wind, unless it is a very windy day and in that case, you are going to get blown around no matter what wheels you have on the bike. They climb really well, as good as my 1300 gram aluminum wheelset. They get up to speed very quickly and hold speed better than my Mavic Ksyrum wheels. The one draw back is that they do not brake as well as aluminum wheels. I will try some different pads and see how they do; Campy pads are reported to be very good. I have used Swisstop and they are average at best. See if you can go to a demo day and try some on your bike and then decide. Now, would I spend $2800 on Zipp, HED, Reynolds, or Enve carbon wheels? I would not but many others do. If this purchase will be your first foray into carbon wheels, and you are willing to shell out about $1300, the Boyd wheels are a good value. Write to them and you will likely get a response from Boyd Johnson, owner of the company, to guide you in your decision making process. Otherwise, look at some of the new wide profile aluminum wheels. If you ride with others who have the type of wheels you aspire, ask to try their bike and see how they feel. I would think that wide rims with 700 x 25 or greater tires at 85 psi will really get your attention for comfort and handling, be these carbon or aluminum.
Quoted: 129 Post(s)
I use both zipp 303 and various alloy rims. my 303s are tubular and 150g lighter than my lightest alloy wheels.
yes they are faster, but not a lot faster.
if most of your riding is on hilly terrain and your average speed is under 18mph don't bother. If you average 20mph+ you will see more benefit from deeper rims.
Quoted: 550 Post(s)
Liked 325 Times
Liked 58 Times
Do you really expect us to believe that you can sense a such a small difference in acceleration and deceleration. Ridiculous. Maybe the stopwatch could see it over 20 miles, but I don't believe you can feel it.
