Seat Post Insertion Question
OldSchool
So I am looking at this rather clean frame advertised as..... "No dents of any kind and frame is solid and straight."
Next line down is this beauty....."Takes a 27.2mm seat post. Seatpost goes in about halfway then requires some effort to go further. If you ride the saddle height where it should be on a 54cm frame, then you will have no problems."
I emailed him some questions about this. I asked to insert the post in the seat tube, mark the post at the top of the seat tube when it begins to hang up, take the post out and measure and tell me how far into the seat tube the seat post goes before it starts to hang up. No responses so far.
Other than a very slightly dented seat tube, what other explanation could there be for this? Thanks for any info!
Quoted: 1609 Post(s)
Liked 2,216 Times
Corruption like rust or gunk is one option. I would ask him to shine a light down the ST and explain what he thinks the reason for the hangup based on what he can see.
52psi
Quoted: 790 Post(s)
Liked 802 Times
Was a very neglected bike.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
My guess is the seller has tried this with only one seat post; so the problem could be on the seat post rather than on the seat tube.
Other than that, it's possible the seat tube was reamed out only as far as seemed necessary at the time.
Bear in mind that seat posts come in a variety of lengths, so we're talking about half of an unkown number.
Whatever the problem is, I doubt it would prevent me from buying a frame I wanted.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 556 Post(s)
Liked 132 Times
Could just possibly be the post he's using too. But I'd vote for roughness, or corrosion, starting where the end of the post sat all these years.
*Rudi beat me to it.
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times
I bought a brand new (NOS) Italian frame a few years ago that was sized for a 27.2 post. However, my mechanic had to ream out the seat tube quite a bit to fit a seatpost in it due to paint overspray and perhaps other issues.
Decrepit Member
Like others here, I suspect surface rust inside the seat tube below where the seller normally has the seatpost positioned. Reaming the seat tube - about a one minute job - should fix the problem.
Liked 2,216 Times
Should it be corrosion, you can use a 12Ga brass brush to knock off the loose stuff followed by a brake honing tool.
Quoted: 113 Post(s)
Liked 16 Times
may not have ever been reamed in the first place. Most frames need reaming as the heat from brazing distorts the tubes at the junctions. Usually this just means reaming the junction a bit.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
OldSchool
OldSchool
Quoted: 113 Post(s)
Liked 16 Times
reaming tools are of limited length, usually just to ream the distorted tube junction section, so if the problem is further down it won't help. I would use the brass brush and hone tool first to see if that helps. It's unlikely to damage the seat tube from forcing a post in, and more likely to damage the post. I have seen a bulged seat-tube from a forced in oversized post, but that was only once. That person must have been pretty strong to do that.
Decrepit Member
If there is a concern about the reamer cutting too deeply into the tubing wall, turn the handle counter-clockwise (against the cutter edges) instead of clockwise.
