Google Earth to plan rides?
I like 3.14!!!
Does anyone use Google Earth to plan their rides? Or am I the only geek here?
I love it, you can measure your planned route distance and everything (Tools|Measure|Path).
Get it here!
Get it here!
Quoted: 19 Post(s)
Love it! I have found so many little roads around the area of my house, that I have never been on before. I find it really helps to find routes of different lengths etc.
-D
-D
The Truth
Bikes: Felt f4c, Felt RXC, Guerciotti Khaybar,Guerciotti EM-2, Cervelo P-3.
I use it all of the time, it is truly a great help. Plus for all of you Detroiters look at the old Tiger stadium on Google Earth and you can see how down-hill it went.
I like 3.14!!!
-D
-D
I like 3.14!!!
Bikes: Fuji Sagres
Don't forget the altitude information, certainly a plus when planning routes that I've never rode before.
www.nycbikemaps.com
for those in the NYC area. I have set up a network link for New York City's bike paths, bike lanes, & greenways.
you can download the file here: https://www.nycbikemaps.com/googleearth.html
Zippy Engineer
Bikes: Bianchi 928, Bianchi Pista Concept 2004, Surly Steamroller, 1998 Schwinn Factory Team Homegrown, 1999 Schwinn Homegrown Factory, 2000 Schwinn Panther, Niner EMD9
Rawwrrrrrrrrr!
Bikes: 2009 Specialized Ruby Sworks SL w/SRAM Red; 2006 Fuji Team RC; 2008 Felt F1x; 1980's Lotus Excelle; Mangusta FG/SS; Rossin (yet to be built up)
It is a wonderful tool! But I must caution you : Old dirt country roads do not appear differenly than normal ones with Google Earth. They all look the same on the map 'till you get there.
Aspiring bat
I just downloaded it, but all I'm getting is a white map with very faint gray lines for roads. What am I doing wrong?
hill hater
Location: norton ohio 5.5 miles from center road tow path trail head
Bikes: cannondale t400 1987 model and a raleigh gran prix from 1973
I like topo 5.0 to plan routes. Tip set start and end points first then add vias other wise topo does some realy odd things
Originally Posted by wolfpack
I like 3.14!!!
I like 3.14!!!
Originally Posted by johnnygofaster
This is worth checking out. I use it for running mostly. Plus you get a URL when you're done to send/keep/whatever.
shut up and ride
Bikes: supersix hi-mod,burley duet tandem,woodrup track,cannondale cross,specialized road
this is the one to use. it give you distance and elevations, you can export the route and and create a url
Aspiring bat
Originally Posted by (Y(L|S+
Can you see any detail (like houses, trees, lakes) when you zoom in a allow it to stream 100%? Granted the satelite picture is a bit washed out but I can make out a lot of detail. Where do you live? Your location may be in the low-res area.
I live in small town, but I tried some urban areas as well and didn't fare much better. The best I did was in Detroit. I got a few gray blocks here and there... nothing recognizable though. Maybe it has something to do with the fact that I have dial-up?
Pain ?? What Pain !!
Bikes: 2010 Felt F75
Use it all the time, a great tool. The mileages are amazingly accurate. I make my own cue sheets using the info and it's right on.
I like 3.14!!!
I like 3.14!!!
Try using gmap-pedometer. It still may take a bit of time but it should be a lot faster than Google Earth.
How do you get elevation plots from Google Earth?
Do you need the +Plus option?
Is it a graph like GMAP's?
Please post screenshots.
Thanks
Thanks
Tête de Limace
I usually use gmap pedometer for that kinda stuff... simple (important for me) and no download required. I hadn't considered using the google earth thing. didn't know you could map out routes like that. I'll give it a try, thanks for the link.
Bikes: '95 Passage, 84 Fillipi Elmer, 72 PX-10
Geobike does a great job with Google Earth for RAGBRAI.
https://www.geobike.com/geobike/gbmain.shtml
https://www.geobike.com/geobike/RAGBRAI/r34.kmz
I like 3.14!!!
Thanks
Thanks
