Shimano Altus - lost washer replacement?
Old 04-23-20, 11:44 AM
russtopherb
russtopherb's Avatar
Bikes: 1995 Specialized Hardrock Sport, 2019 Jamis Allegro Sport
Quoted: 11 Post(s)
Liked 25 Times in 16 Posts
Rear brake fell apart on my ride today, looks like a loose nut caused it. I was on a deserted side road thankfully and recovered all the parts save for the washer noted below. Is it possible to find another one of these, or is it just not worth it? Iíve seen new assemblies for around $12 so Iím assuming thatís probably the better way to go?
russtopherb is offline
Old 04-23-20, 12:11 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1008 Post(s)
Liked 226 Times in 178 Posts
What's it look like?
You should still have 3 left.
Bill Kapaun is offline
Old 04-23-20, 12:23 PM
Wilfred Laurier
SeŮor Member
Wilfred Laurier's Avatar
Quoted: 627 Post(s)
Liked 259 Times in 190 Posts
Those brakes used to come equipped with a little washer that helped toe in the brake pad when the nut was tightened. IIRC, it wasn't actually necessary if you know how the brakes are supposed to be adjusted.
Wilfred Laurier is offline
Likes For Wilfred Laurier:
Old 04-23-20, 12:26 PM
russtopherb
Quoted: 11 Post(s)
The thought did occur to swap one out from the front brake to the rear and either go washerless on one side of the front, or see if I had something in my box o'loose stuff that might fit the bill. I'm not much of a mechanic and my LBS is unfortunately closed right now, so figured asking around was worth the shot
Old 04-23-20, 12:30 PM
Bill Kapaun
I guess I won't care what it looks like either.
Without providing the model# of WHICH Altus, good luck.
Old 04-23-20, 01:00 PM
russtopherb
Quoted: 11 Post(s)
Sorry, is the image I put in the first post not showing up for you?
Old 04-23-20, 01:44 PM
Bill Kapaun
No.
The arrow is pointing to where one of "you have 3 left" is missing.
A pic of ONE of those would be helpful. It might be recognizeabley "standard enough" that it would commonly be found in a used parts bin or junker bike.
Shimano also has tech docs with part names/numbers, but one must know the model# of the brake. BR-something.
I'm done.
Old 04-23-20, 01:50 PM
brian3069
brian3069's Avatar
Bikes: Raleigh Supercourse
Quoted: 150 Post(s)
Liked 61 Times in 34 Posts
I have a spare washer, it's yours for the cost of postage.
brian3069 is offline
Likes For brian3069:
Old 04-28-20, 02:41 PM
russtopherb
Quoted: 11 Post(s)
Just wanted to come in here and post thanks and gratitude to brian3069 for shipping me the washer I lost when my brake fell apart. It was a very gracious gesture on his part to help out. Many thanks, again!!
Likes For russtopherb:
