How much should my feet pivot on 1980s Look pedals?
I have a set of 1980s Look Red and White pedals, and as it has been a very long time since I bought them (new).
I don't remember how much my foot should be allowed to pivot side to side when clipped in.
I have taken up cycling again after many years off my bike, and it seems like I can pivot my heel left and right more than I remember in my teens.
This is not causing me any problems, I just want to know if I may be looking at getting a fresh set of delta cleats for my pedals...
Does anyone here know is there is an expected angle that I shouldn't be able to exceed?
G
G
aged to perfection
Quoted: 840 Post(s)
Liked 1,262 Times
If I correctly understand your question, your feet are "rotating" to the extent of the pedal's float capability, is that correct ?
what you might look at is the LATERAL placement of the cleats on the shoes.
Ideally the cleats should lie on the imaginary thrust axis of your foot. If that is the case then the cleats will not move very much.
At least in theory. I run SPD cleats with a few degrees of float. But I think paying attention.to the lateral, as well as the axial orientation of the cleat will partially address your question.
/markp
/markp
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12784 Post(s)
Liked 7,697 Times
IIRC Look cleats came in a couple or 3 colors that indicated different amounts of float.
...googling...
Look Delta cleats
Red 9° float, Black 0° float.
...googling...
Look Delta cleats
Likes For LesterOfPuppets:
Quoted: 140 Post(s)
Liked 163 Times
Sounds like you are using Delta cleats that allow 9 degrees of float. That's quite a bit of float, as a comparison the later Look Keo cleats (not compatible with your older Look pedals) are available in three float options, 0 degrees, 4.5 degrees, and 9 degrees. For the sake of one more comparison, the most popular clipless "standard" these days is Shimano SPD (uses small steel cleats, originally designed with mountain bikes in mind), those provide 4.5 degrees of float.
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,844 Times
Iirc
6° float on red cleats
0° float on black cleats
wear the plastic cleats and/or loosen the tensioner and you may get more than 6° before clipping-out.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
The difference you're feeling between past and present could just be aging. Many legs start to bow in 50's and that's enough to tweak your pedal alignment.
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 167 Post(s)
Liked 92 Times
There have also been some changes to the rear ends of Look Delta cleats over the years and this can affect how float works with their pedals. Their later Delta pedals had float control knobs on the back of the lever and this worked differently depending on which delta cleat version you were using, Earlier delta cleats had straight across rear edges while later delta cleats had a moderate semicircle cut out of the rear edge. This part of the cleat is right where the float system comes into play.
Quoted: 656 Post(s)
Liked 469 Times
Delta specs from the LOOK website. Keo added a gray cleat with 4.5 degrees of float
GENERAL Use Road & Indoor bike
Material Polyacetal & PTFE
Angular freedom 0° & 9° (Black & Red)
Lateral adjustment 4 mm
Longitudinal adjustment 12 mm
My personal experience is with Keos. The reds allowed too much movement for my liking. The grays are perfect when they’re brand new but they get a little floaty as they wear down. I always planned to try black but my riding has mellowed out to a point I don’t think it really matters for me. All the YMMV disclaimers apply.
Thanks all!
I have paid a bit more attention to the angle and it is not as large as I had supposed (9 degrees seems about right).
To be fair, I have only been on about 15 rides since I dusted off the bike again....
G
G
