Seatpost Minimum Insertion
When seatpost manufacturers specify a minimum insertion line on their seatposts, is it at point A or B on the frame?
Quoted: 1324 Post(s)
Liked 927 Times
I'd have my minimum insertion mark inserted at least as far as the weld below 'B'. Cantilever force can snap off the protruding seattube if there's too much seat post above that weld and not enough below it. I've seen frames ruined because that section between what you have marked 'A' and 'B' broke off because there wasn't enough seatpost below it.
Cheers
Cheers
Likes For Miele Man:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
If I wasn't at least half way through the top tube I'd be looking at a longer post.
More if I were big & strong
answer is C , bottom of the seat post at least in as far as the bottom of where the top tube joins the seat tube..
On my touring bike build I had a classic Campagnolo seatpost I wanted to use, since it was close to max ( because of sloping top tube)
I had a welder add a length of a common Kalloy seat post, that diameter, then get the weld bead machined down smooth..
Likes For fietsbob:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
If you are a larger rider than get the seatpost in farther and get something of length.
When buying used bikes first thing to look at after evidence of front end damage is condition of seat lug. Or on a frame like one in top post, top of seat tube. They are very very frequently damaged from inadequate insertion. Back when all frames were sorta similar the rule was 6 to 7 cm inside the frame. Make that 2-1/2” to 3” if you can’t speak metric. Modern frames with sloping top tubes will have huge amounts of seatpost showing. Means you need more post inside frame. Frames break and bend at this point all the time. There is not ever any reason to skimp on seatpost insertion.
On old steel frames it was possible to do lots of bending and repair that damaged seat lug. Sometimes it would be worth it to get out the torch and some brass. Modern frames mostly they get scrapped. Anyone thinking about how little insertion they can get away with will soon be scrapping a frame. Plus medical bills.
Likes For 63rickert:
To be clear; the minimum insertion line on the seat post is to be at the B height ,
so the rest of the seatpost below that line is below that point?
How long is the length of that post below that minimum line ?
and as I offered above, it should be the spanning the miter width of the top tube .....
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
Quoted: 604 Post(s)
Liked 1,064 Times
This is in chapter 10 of my Park Tool School instructor manual.
Tim
Tim
Likes For tkamd73:
Quoted: 1608 Post(s)
Liked 2,216 Times
I measured two Campagnolo posts. Both, a Chorus Aero and a NR, measured 57mm (2.25:") from the top of the line to the end of the post. I believe that may be enough to get the end to the bottom of the seat lug. Your risk.
Quoted: 604 Post(s)
Liked 1,064 Times
Liked 927 Times
Any seatpost that was inserted only to Point B would have a lot of leverage/torque on that part of the seattube that's above the toptube of the bike. The more seatpost above the toptube and the heavier the rider the more leverage/torque there is. Its a failure waiting to happen. I tell people to make sure that at least TWO INCHES of their seatpost is BELOW the top of their toptube. I'm glad you did that. Having a seattube break off on a long ride is unpleasane at bast dangerous to the rider, and often the ruination of the frame.
Cheers
Cheers
