Wheel wobble and gear jumping
Bikes: 2005 Trek 1500
I bought a Trek 1500 and love the bike..but I have a couple of questions. The bike is about 30 days old.
1) Both tires when spinning I notice a slight wobble side to side....is this common? It is not rubbing the brake pads, but I see the wobble. Can this be fixed by truing the spokes?
2) I am using a trainer and the gears jump on the rear. Is there different loads on the bike from the trainer to the road? Would this affect the gears?
Just wondering.
Scott
Just wondering.
Scott
By-Tor...or the Snow Dog?
Bikes: Bianchi Cross Concept, Flyte Srs-3
You need your derailer adjusted, for the gear shifting, thats what i think, and the wheel most likely needs to be trued, that cost like 156 if brouhgt to a shop.
*15 $
Metaphorically speaking
Bikes: Cannondale R600 ultegra spec
If you bought the bike new, then the LBS you bought it from should be able to true/adjust for you at no charge. Both issues are minor adjustments, you will feel better about the bike when you have them fixed.
