Upgrading from steel: Canyon Endurace CF vs Specialized Roubaix
I've had a nice comfy steel road bike for a long time and am thinking about getting a carbon road endurance geo bike. I'm assuming both these bikes would fit the bill but I am wondering if my posterior chain can handle the saddle to handlebar drop. Right now my fitter has my bars just a couple mm below my saddle. With these forks it doesn't look like there's much wiggle room for fitting. Any thoughts appreciated.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I have to question the presupposition that CF is an upgrade from steel.
In any case, I would experiment with alternate fits before purchasing a new bike. If the new bike has an inferior fit, it won't be an upgrade regardless of how great the frame material is.
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,893 Times
My Canyon Endurace CF SL 7.0 Disk (man, that's a long name!) came with 37.5 mm worth of spacers, so you've got like 1 1/2" of adjustment there. I ended up with 12.5 under the stem. Fits for me with about 8.5 cm of drop. That's a Large, with 78cm saddle height.
Quoted: 9653 Post(s)
Liked 6,365 Times
I'm not familiar with the Canyon, but am with the Roubaix as my wife rides one. Since it has the Future Shock, it appears to be a bit more limited in the amount you can raise or lower the stem. You might also consider the Domane (which I ride) which has more room to move the stem down from its factory setting.
Liked 11,893 Times
Likes For genejockey:
Occam's Rotor
Liked 2,331 Times
The Domane is closest to the geometry of my custom steel bike, which has a similar (lack of) drop to that of the OP bike. Of the three options now listed, Canyon has the least forgiving geometry.
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
Roubaix can easily get the bars up to level with the saddle but not much higher than that.
Somewhere, a village is missing its idiot.
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
I'd talk with your shop about the Roubaix, the bars sit pretty high on it anyways and it sounds like it could accommodate you. The combination of the flex in the seat tube and in the handlebars also makes it more tolerant in general for your body.
I also switched from 20 years of steel to a Roubaix, about a year ago. It is night and day on overall comfort, especially if you throw on wider tires which my old frame could not fit.
Bikes: Canyon Endurace, Merckx liege 75, Cinelli Vigorelli
Quoted: 167 Post(s)
Liked 114 Times
Had a Canyon Endurace CF for 2 years & would choose it again. You can ask me anything.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1944 Post(s)
Liked 1,465 Times
Giant Defy. Awesome bike, I have a 2019 Advanced Pro 0.
Quoted: 33 Post(s)
Liked 21 Times
The Roubaix
at least up to 2019 will take any 1.125 stem. If you need to raise the front end you can simply install any goofy tall stem you want. And the Roubaix headtube tends to be longer than most so you your bars will be higher than most.
Depends on saddle height. I've got the stem as high as it will go on my Roubaix using the tall head cap and 3 x 5mm spacers, and I still have about 75mm saddle to bar drop.
Quoted: 1248 Post(s)
Liked 1,323 Times
No need for that, he probably is right. Try a shorter stem, short reach bars, zero offset post. Specialized knows who is buying the Roubaix and built it accordingly.
Liked 1,323 Times
No need to insulted other poster for a logical comment. The stack on a Roubaix is much higher than a race bike plus as I mentioned there are numerous things that can be done to reduce reach.
His signature is "Somewhere, a village is missing its idiot." Figured he was talking about himself...
I know. I've have reduced the reach with a shorter stem. Long legs in proportion to height > saddle is set higher than average. Short torso in proportion to height > shorter than average reach for one's height is needed. The end result is that even with the higher stack of the Roubaix, someone with long legs and short torso is going to have pretty much the same saddle to bar drop as a more "normally" proportioned person on a race bike with lower stack.
So, can the Roubaix can easily get the bars up to level with the saddle? If you have short legs, sure. If not, it depends.
