How much air goes from the tire to the pump when you plug it on the valve?
Should Be More Popular
Quoted: 22586 Post(s)
Liked 8,924 Times
Wrong. As someone else ( DaveSSS ) posted earlier as soon as you stop pumping the pressure in the tube forces the valve closed. You don't lose any pressure from a presta valve when removing the pump head. The air you hear is coming from the pump, not the tube. It's no 'theory'...the pump head doesn't depress the valve, air pressure from the pump does. You continue to get a pressure reading when you stop pumping because there is still positive pressure in the pump/hose. Oddly enough it's the same as what the pressure is in the tube.
However, SOME OTHER pumps DO INDEED depress the valve when you put the chuck on. This is the type the OP has.
Quoted: 8273 Post(s)
Liked 9,028 Times
Here is a pump with an integrated bleed valve on the pump head.
Blackburn Core Pro Floor Pump | The Colorado Cyclist
Liked 8,924 Times
Likes For datlas:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I've never seen one that does depress the valve when the head is put on, but I guess that doesn't mean they couldn't exist. But...they still wouldn't release any meaningful amount of air when removed because as soon as you stop putting pressure on the valve it closes...instantaneously.
Likes For asgelle:
Liked 9,028 Times
Of course it wouldn't lose air if you got it straight off. I was talking about the times when you have a little trouble pulling it off cleanly.
And I don't say "brifters" either.
Likes For big john:
Quoted: 389 Post(s)
Liked 255 Times
Quoted: 18883 Post(s)
Liked 10,646 Times
So you're saying you get no reading on the gauge when you first install the pump head? I have two floor pumps with different heads and they both show pressure before pumping.
Sometimes when trying to remove the pump head after inflating the tire if it's in an awkward position and I twist it around air will escape from the tire. Sure, if it is removed straight off the only air released is from the hose but if you fumble around with it the tire will lose air.
https://www.amazon.com/KUWAHARA-HIRA...31473976&psc=1
Liked 8,924 Times
Yes, that's what we're saying. Silca heads never press the top nut down. Any head that does that defeats the whole purpose of using presta valve stems. I recently bought a hirame pump head. Pricey, but really nice. It's got an easy to push lever to clamp it to the stem. The collar adjusts to difference stem diameter. Some valve stems for tubeless have a no-thread small diameter right at the top.
Likes For datlas:
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
Liked 9,456 Times
Liked 9,028 Times
Because the Presta valve is open when you do this, pressing the pump head on usually pushes the valve tip down opening the valve and releasing some air. If a person is fumble fingered when putting on this type of chuck, they can lose a lot or almost all the air in the tire meaning more pumping is required. If you were trying to only top of the tire before a ride this can be annoying."
This is what is familiar to me. The last pump head I wore out would lose all the air before I could inflate a tire, it was leaking so bad. Obviously it was holding the valve open. I admit to not having a Silca pump head in my arsenal.
Bikes: SL8 Pro, TCR beater
Quoted: 986 Post(s)
Liked 583 Times
Liked 9,456 Times
Does yours have a universal head on it that'll service Presta and Schrader through the same nozzle? My pump does and it exhibits the same behavior; I'm thinking that it might be common or even necessary for that type of head.
I also have a couple of old brass silca heads with no lever. They have a thick rubber bushing with a hole size that is controlled by a threaded collar. As the hole gets larger, tighten the collar some more. Only friction holds it in place.
https://www.biketiresdirect.com/prod...-presta-chucks
Liked 8,924 Times
Agree.
I think it's hilarious that so many people don't understand the specific purpose of a presta valve. It was invented long ago and pump manufacturers have decided to negate the design with stupid pump heads. I have one silca head that has a thread-on Schrader connection at the top, so both can be used.
Liked 9,456 Times
Likes For WhyFi:
Liked 10,646 Times
Likes For Seattle Forrest:
Liked 9,456 Times
Ask the manufacturer of your deep profile carbon rims if it's OK to drill out their rims for a Schrader valve.
Likes For DaveSSS:
Quoted: 896 Post(s)
Liked 2,062 Times
A presta pump that mechanically depresses the valve is an abomination.
But the answer is clearly 42psi for a high pressure tire, 4.2psi for a low pressure tire, and 0.42bar for the civilized world.
Likes For downtube42:
