Cutting aluminum tubing with an elec. miter saw?
I'm no metalurgist, so I thought I would ask the question before ruining some tubes, or a tool. I am trying to cut 7/8", .049" wall thickness 6061-T6 aluminum alloy tubing. I have a 10" miter saw in the garage. It has a carbide tipped blade for fast wood cutting. When I read the shop manual for the saw, it says to use a carbide tipped blade to cut things like aluminum window screen extrusions and the like, but surprise , nothing about making bike parts.
So...will that carbide tipped wood blade work for the tubing, or do I need a cutting disc like I see in the home improvement stores? Or is that disc for steel angles and the like only? There seems to be a difference when cutting ferrous vs. non-ferrous metals from the literature I've read. Any advice?
Aluminum will clog an abrasive disk. The miter saw and carbide blade will work very well. The more teeth on the blade, the better. I have cut up to 1" thick aluminum plate with my table saw and a fine toothed carbide blade.
Wear eye protection. You don't want a hot metal chip in your eye.
MFA
Bikes: 1973 Italvega Nouvo Record; 1965 Hercules; 1982-83 Schwinn Mystery MTB
Agreed. It should work. Cut slowly, though, and clamp your work to the cutting bed. In my younger days, I once cut too quickly through some aluminum square tube stock. It bound up and tore apart with big pieces wedged deep inside the blade guard. Don't do that.
Even better and safer if you have one, use a tubing cutter for copper plumbing. Again go slowly to avoid crushing the tube.
Bikes: '98 Kona Kula, '8X Univega Sportour SS, '81 Trek 710
Your carbide-tipped miter saw will hardly notice cutting .049" tubing. I have definitely cut thicker than that without any issues. Like they said above, the more teeth the better but most carbide-tipped blades should be fine.
"this is not suck"
it'll cut easy, you'll see
don't forget to deburr the cut edge when done or you'll slice your self open on it.
Thanks! That is good news! Now what kind of wax is this, where do I get it, and is it applied to the blade or the aluminum? I would go the tubing cutter route as I have one, but I am making these cuts at a 22.5 degree angle.
"this is not suck"
go down to the home depot, and look in the tool section, where they have the table saw blades you'll see a paper tube with waxy goo for making smooth cuts in wood or whatever (or just ask for it). then just turn on the table saw and push the wax stick into the blade for a second, and then make your cut.
What you pay for a new saw blade you can buy a cheap pipe cutter and the cut will be nice and straight.
George
George
You Know!? For Kids!
Unless of course he wants angled cuts.
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
Scott
Bikes: Too Many
Just be careful and cut slowly through the aluminum. The saw blades your using are intended for wood so the rake on the teeth are at a much higher angle than if they were designed for cutting metal. This can cause a tooth to hangup in the aluminum. If that happens the tubbing could be thrown out and away from the blade causing serious injury. Cutting very slowly reduces the chance of this happening. If your going to be doing a lot of cutting you should consider purchasing a blade made for cutting aluminum like this.
https://www.toolstoday.com/p-5309-alu...-material.aspx
Keeping A Low Profile
Bikes: Specialized Hardrock Sport [1998], Dahon Speed P8 2007, 1994 Diamond Back Ascent and a couple of Schwinn Stingrays [one boys, one girls] from circa 1977.
Wear hearing protection also. Not only for this . . . but anytime you use a power saw or grinder. I didn't and my high-frequency hearing is shot. Save it while you can.
Bikes: Giant OCR 2
I did a project where I needed to cut a bunch of 1/2" HDPE sheeting (the white cutting board material) on my table saw. I picked up a 10" 80-tooth carbide blade from Harbor Freight for $12.99. I have also used it on my mitre saw to cut PVC pipe. It did an outstanding job at both.
They also have a 12" version for $29.99 if you need that size. Both of my saws are 10".
