Going faster on a Dahon Briza D7
Hi everyone. I have a Briza D7 but find it a bit slow when cycling with others and would like to be able to go faster without compromising my ability to go up hill. I have found threads elsewhere that suggest it is possible to fit a front derailleur to the bike using a large LitePro backet (sorry but I can't post the link due to being a newbie!!)
Could someone with more knowledge than me discuss the pros and cons and explain what I would need in terms of the front crankset etc.to get the desired improvements?
Cheapest option is to replace your cassette with one that will increase your gear range.
@kayakindude I'm a bit of a newbie, bike tech wise, so would that be a cassette with more rings or the same number but of different ratios?
https://www.universalcycles.com/shopping/product_details.php?id=47234&gclid=CjwKCAjw57b3BRBlEiwA1ImytlzEYvQKFcd4tZhCeg5HbKOj6scGvtzLiB7cVqMwS f9xEjTXiSqzPhoCmPAQAvD_BwE
I did upgrade to a 56 tooth crank, but start with the cheapest option. My combo gets me riding comfortably around a 16mph average, so between 12-20 mph based on wind and elevation.
@kayakindude thanks for that. I'll look further into that option.
Physics of air resistance is a known factor that can be measured.. going faster, you have more of it..
I was trying to find the cassette specification as it is now, but it seems impossible to find on the web anyway.
55+ Club,...
Bikes: 9+,...
Quoted: 1112 Post(s)
Liked 845 Times
Question: is it a "cassette", or is it a "freewheel"? That makes a world of difference for upgradeability. I would know,...
Well the good news is it's a cassette. Bad news is it already has 11 teeth.
Next step is count the number of teeth on your crank. I suspect 52 teeth or less.
Likes For kayakindude:
The latest version of the Briza D8 has a 46t crank so likely similar, giving max gear inches around 95.
It might be easier/cheaper to fit some lighter weight tyres than the Schwalbe Marathon to gain a few kmh to keep up with friends. Increases the chances of them having to wait while you fix a puncture though.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 238 Times
but, changing the chainring only will affect the capability do go up hill. If current up hill gear is required then , it would need a front derailleur using a bracket, FD twin crankset and chain set (44/56 Road/triathlete set or classic 39/53 road set)
half way commuter
[QUOTE= Falconista.....easier/cheaper to fit some lighter weight tyres than the Schwalbe Marathon to gain a few kmh to keep up with friends. Increases the chances of them having to wait while you fix a puncture though.[/QUOTE]
+1, I got Dahon EoS D9, also with 24" tire, stock it got Scwalbe Kojak 24x1.5, I think it would be lighter on pedal compare to stock Briza tire 24x1.75.
True if the OP is not spinning out or barely using the lowest range. I found no issues going my route and still rarely run the lowest cog.
Quoted: 264 Post(s)
Liked 238 Times
