Addiction LXXIX
#2026
Quoted: 20810 Post(s)
Liked 9,456 Times
Remember I asked about sleeving cables under the BB? No? Well, after spraying lube, dry and wet, along the exposed path and working the FD by hand, it was still sticking, so I replaced the cable and sleeved it. Now it’s like a new system.
The FD cable runs in the bottom slot from right to left and through the window in the tab. It all looks pretty smooth, but it must bind somewhere. It came sleeved, but I took it off when I replaced the cables a month ago.
#2027
Liked 9,456 Times
#2028
Bikes: Shmikes
Quoted: 10167 Post(s)
Liked 5,860 Times
No, it doesn’t touch there. I just hope the happy shifting lasts for a while. The cables are a pain in the ass on that bike. You have the same guide, if I’m not mistaken.
#2029
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
I think I’ve had to charge it maybe 5 times this summer. So pretty good. The Varia usually runs out of juice before the 530, so I charge them both at the same time
#2030
Liked 9,456 Times
It's about an equal pain in the ass compared to the Domane, which is the only other internally routed frame that I've worked with. The FD wasn't horrible, but the RD was a bit of a pain. And yeah, same cable guide.
#2031
So it is
Quoted: 11401 Post(s)
Liked 4,756 Times
https://www.westernbikeworks.com/pro...-edge-520-plus
This works well for me, but I upgraded from the Edge 500, so it was a big difference. Not sure why,other than the fact I was able to snag mine for under $200.00. I do have an issue connecting to my phone, but I'm not really trying too hard. My watch is my connection to the other world, if need be.
Likes For LAJ:
#2032
Should Be More Popular
Quoted: 22597 Post(s)
Liked 8,925 Times
Likes For datlas:
#2033
Liked 9,456 Times
Likes For phrantic09:
#2035
Liked 9,456 Times
#2036
Bikes: Shmikes
Liked 5,860 Times
The liner tubing makes it a lot easier. It also occurs to me I might have somehow gotten the front and rear cables crossed inside the BB, but it seems unlikely.
#2037
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Beautiful! I, unfortunately, can no longer eat (modern) wheat. I've read that they changed the formula, within the past 40 years, for higher production, at the expense of nutrition. It is bad for my skin and possibly my energy levels
#2038
Liked 8,925 Times
It’s tasty, but it’s NOT gluten free.
#2039
Liked 9,456 Times
I thought the same thing about the Domane, but after fiddling around with it to make sure that it wasn't the case, the FD still shifted worse than the Cervelo or Haanjo.
#2040
Quoted: 10236 Post(s)
Liked 5,184 Times
#2041
VFL For Life
Bikes: Velo Volmobile
Quoted: 28610 Post(s)
Liked 1,857 Times
#2042
Liked 8,925 Times
Likes For datlas:
#2043
Liked 8,925 Times
#2044
Quoted: 3359 Post(s)
Liked 3,638 Times
A little bit of both. I realize that it's out of warranty, but it's close and it's also a problem that should fall under defect, IMO. Also, some of the features on the Garmin 530 (like the color screen, on-board nav, ANT+ light control, etc) are making the Bolt look dated. I think that the Wahoo Roam is more on par, but that's also $150 more than the Bolt and $80 more than the 530.
I'm looking into getting a GPS for next season and the two main contenders are the Bolt and 530. The additional nav features on the Garmin look nice but it looks like you can get most of the same functionality using a phone with the Bolt? I can see the actual street names being super handy in an urban environment, but out here in the boonies it's probably not something I would miss a lot.
Plus I'd need to get a bluetooth/ANT heart rate monitor, so that kind of makes me lean towards the Bolt.
I do like that the 530 is a bit more low-profile, though.
#2045
VFL For Life
Liked 1,857 Times
Consumption will require a fork.
Likes For Velo Vol:
#2046
Liked 9,456 Times
Ah I see.
Likes For WhyFi:
#2047
Liked 5,184 Times
How epic are we talking datlas?
#2048
Liked 8,925 Times
#2049
Liked 9,456 Times
I'm thinking that you might cling to the #5 spot. Might.
#2050
Liked 8,925 Times
