Specialized Fuse Seat Tube Troubles
Hi there!
So I recently bought a lightly used Specialized 27.5+ Fuse 2020. It comes with a TranzX 120mm dropper post. I was considering switching to a One Up 180mm or 210mm. However I have run into a few problems!
Problem #1 : the seat tube internal diameter on the Fuse looks to be 34.9mm but the current TranzX dropper is around ~29mm so there's an "adjustable" tapered bushing or adapter to make it a tight fit (pictured). However when everything is installed I cannot make the bushing slide all the way down into the seat tube, about 2 inches sticks out. And more importantly, I cannot even remove the bushing, I can pull it up a certain amount and then it stops: I can't slide it out of the seat tube - so I cannot install a different larger dropper post. Has anyone else experience anything like this? Is my only option to cut / break it and replace it?
Problem #2 : The threads for the water bottle cage stick out into the interior of the seat tube (pictured) thereby preventing a seat post of over 210mm being inserted fully. Has anyone heard of drilling out / dremelling flat this protrusion? - in order to insert the seat post another 50mm.
Advanced Slacker
Quoted: 2749 Post(s)
Liked 2,516 Times
I see no pictures.
One Up has a great online tool to figure out your max dropper post length.
The Specialized website lists the Fuse as having a 30.9 seat post diameter, so you might be stuck with the bushing. I haven't heard of anyone dremeling out the threads. You would lose use of that bosses if you went this route.
Pictures would help.
That sounds like a tricky problem.
For problem 1 you could try to use a screwdriver and hammer to gently tap it out of the tube (if I understand the situation correctly)
I have removed the water bottle bolts with a drill.
It only works if the frame allows you to get in front of the whole with the power drill.
Then just drill out the thread.
Good luck!
Good luck!
