Freehub service and clanking question
I got caught in a downpour a few days ago and have never rode in the rain before. I dried my bike and lubed most things back up. Today when I rode I would get random clanking sound. Almost like when you are free wheeling and then take off. It mostly happened at a higher cadence. Not when out of the saddle. I rode the same route I've done a million times. My wheels have about 5 to 6 thousands miles on them and the hubs have never been serviced. My LBS advised me to try and clean/lube the pawls in the hub. When looking around some people said to use grease, some said oil, some both. I put a little grease on the teeth, cleaned and used tri flow on the pawls, and greased the bearing surfaces and axel. Nothing looked too horrible when I opened it up. No pawls seemed to be sticking. They did move a little better after cleaning and lubing.
Is there anything else that could be causing this? I won't have a chance to ride it for a few days to test it. The BB and crankset were recently taken apart to stop a ticking which ended up being a pedal.
Quoted: 2599 Post(s)
Liked 1,924 Times
My Internet Expert guess is that your derailers are a bit out of whack, instead of the freehub. Oil your cables and derailer pivot points and see if that helps.
Cleaned and lubed the freehub/pawls. Been on two rides and no changing sounds. Got some different advice from searching.....some said to grease everything, some said only light oil, and my lbs said to grease it. I ended up putting a little waterproof Teflon geese on the bearing surface in the the hub and used Triflow thing lube on the pawls.
Was I wrong? Suggestions for next time?
Likes For Dcmkx2000:
Quoted: 325 Post(s)
Liked 109 Times
