Restoring Silca Impero color?
Señor Member
Quoted: 284 Post(s)
Liked 303 Times
As a throw-in for a recent acquisition, I received a 30-year old Silca Impero frame pump.
I've been able to find great info here about restoring the innards (e.g. link), but I didn't see much about getting the original color back.It was originally white (I can see that where the handle covered the body), but the majority of the plastic is a light butterscotch blonde now.
Anyone have a trick to get it back to white?
I looked at Randy's site for hints, but didn't see anything.
Photographer
Quoted: 105 Post(s)
Liked 98 Times
I just traded one to Rootboy that looked like that, it had a wonderful patina that looked like aged ivory. I liked it but other than repainting I'm not sure how you'd do it.
Scott
Scott
ClassicFuji.posthaven.com.archive
IG @scottryder.surf.cycle
IG @scottryder.fine.art
Bikes: Cinelli, Paramount, Raleigh, Carlton, Zeus, Gemniani, Frejus, Legnano, Pinarello, Falcon
Quoted: 12 Post(s)
Liked 8 Times
Might try rubbing compound and wax, but I think they look nice with the aged look. I've gotten some of the washers on ebay... usually the leather one just needs spreading and a coating of grease to help it seal in the tube.
All Campy All The Time
Bikes: Listed in my signature.
Quoted: 177 Post(s)
Liked 114 Times
Back in the day, when Silcas were available new, I bought a black one new and soon found that it had been painted black over blue plastic. I bet you could repaint yours with model car spray can paint if you made sure to remove all traces of oil and grease. Don't wipe it with lacquer thinner or use lacquer paint as they would certainly wrinkle the base plastic.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 33 Times
Other than painting over the pump with white paint, I'd just leave it as it is as I agree the off-white patina just adds more "C&V character" to the pump. Be careful using stuff like rubbing compound and cleaners with solvents in it, as the old plastic might end up getting damaged as plastics back then weren't very resistant to chemicals. I'd rather just use the mildest cleaners/polish on such old plastic items like "Pledge".
"part timer"
Bikes: 1975 Raleigh Gran Sport, 1978 Bertin C35, 1982 Trek 614, 1983 Trek 620, 1984 Nishiki Seral, 1995 Mercian Ko’M, 1998 Fisher HKEK, 2000 Rivendell RS, 2001 Heron Touring, 2016 Nobilette Custom
Quoted: 114 Post(s)
Liked 160 Times
^^^^ Every time you post that I (in the words of Jimmy Carter) lust in my heart.
Crawlin' up, flyin' down
Quoted: 1052 Post(s)
Liked 2,597 Times
To the OP - the answer is paint. Many frame painters, then and now, would paint Silca pump bodies to match the frame.
The pump barrel itself is plastic - and no, that is not a euphemism for carbon fiber. It's the finest plastic that 1960's or 1970's materials science could produce, which means it absorbs stains and gets dull and stuff like that. Personally, i would not let any kind of solvent near it as I have no clue how any solvent would react with the plastic. I'm not so much concerned about fumes as I am weakening the plastic or making it brittle or otherwise compromising its structural integrity.
Finally, I loves me my Silca pumps, and have them adorning a couple of my bikes because a matching Silca pump looks so kewl, but let's face it - Zefal HPs work significantly better and are much more durable.
I wonder if a Mr. Clean Magic Eraser would clean it up.
Quoted: 5892 Post(s)
Liked 2,755 Times
Anyone have a trick to get it back to white? .
FB
Chain-L site
FB
Chain-L site
Bikes: Cimarrons 1835, 0836, 1767, 3517, 0768, 3408, a LHT, and a couple others
Liked 12 Times
I'm wih the others; leave the delightful patina. If it drives you nuts, sell it, and use the money to offset the cost of an nos pump in bright white on ebay for less than your time and paint supplies would cost.
I had a white Silca that had yellowed over the years that I scraped-down with the edge of a single-sided razor blade. That took the yellowed layer of plastic off and then sanded it with 600 wet or dry sandpaper and then polished it with Simichrome polish (metal polish that happens to polish plastics really well).
You have to work very carefully around the hot-stamped Silca logo.
Quoted: 3464 Post(s)
Liked 2,834 Times
Quoted: 556 Post(s)
Liked 133 Times
I just did the headlamps on my 9 year old truck, but I used Mequiar's Mirror Glaze products. Good stuff. Probably work on a Silca as well. But I'm not going to go trying to get into those intricate casting details on the handle on the one Scott traded me. I'm going to spray paint it.
Quoted: 1617 Post(s)
Liked 2,225 Times
I have two in black of different lengths. One is at least 40 years old and has only had the gasket to the head replaced once. Both look very good with the sheen I remember them having. I would like them to be the same color as the frame but figure that since they travel from one frame to another, black goes with nearly every color! I just picked up my first Z HP. Really heavy compared to the Silca! Although I haven't used it yet, it feels like it could take a lot of abuse.
Liked 2,834 Times
Quoted: 556 Post(s)
Liked 133 Times
That is an issue, for sure. I contemplated filling in the stamping on the one I painted, above, but decided it was painting legs on a snake. And the impression was very shallow. If the old ones with squared handle are in good condition, I try not to mess with them. But the one above was pretty ugly. I like the old ones.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I like the yellowed look.
www.rhmsaddles.com.
www.rhmsaddles.com.
Liked 2,834 Times
Photographer
Quoted: 105 Post(s)
Liked 98 Times
I got rid of that? yeesh.
Another one that I have on my Paramount:
I think the yellowed look works good on a '66
Scott
Scott
Quoted: 838 Post(s)
Liked 2,189 Times
Too bad this post didn't come a few weeks ago. I recently bought a once-white silca in cream color to match the patina on my once-white Cilo Pacer which has also turned cream. I like the patina.
