On the next episode of "'People Who Shouldn't Work on Bikes" ...
Just smang it.
Bikes: Felt F1X, Trek 2300 Composite, Dawes Deadeye
Quoted: 20 Post(s)
Just discovered that the previous owner of my Trek used a die grinder on the chainring to make it clear the chainstay. Anybody else uncover some nightmare repair jobs while going over their used bikes?
Grumpy Old Bugga
Bikes: Hillbrick, Malvern Star Oppy S2, Europa (R.I.P.)
Quoted: 370 Post(s)
Liked 8 Times
Don't be silly, he was removing some unnecessary weight, the extra clearance was just a bonus.
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
ITT: "What'd you **** up that you'd like to blame on someone else?"
This jackass installed the seat clamp on my kilo. It broke.
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
You people are lightweights. I have done far sillier things than that to get a build to work.
Come back when you have something to show me.
jim
jim
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
pro in someone's theory
Bikes: FTP
Quoted: 72 Post(s)
I once used a hammer on a quill stem because it was too high and was bottomed out in the fork. I have no idea what good I thought that would do.
Instant frustration relief.
The former of Epic's Trek had it backwards. The proper method is to tighten crank arm, then put ratchet and socket in back pocket and ride---tighten crank arm until grinding noise stops. Custom fit.
Bikes: 2010 Windsor The Hour, 1982 Fuji Supreme
My brother got a Zebrakenko that the previous owner tried to singlespeed with a quickrelease in back. The wheel kept slipping, of course, so he welded a couple washers onto the dropout to fit the quick release skewer through. My brother ended up using a hacksaw and a file and most of the dropout is now usable. At least he can adjust tension.
Bikes: klein quantum, litespeed tuscany, bianchi pista concept, centurion comp ta, centurion super le mans, traitor ringleader
I've definitely shaved the back of the front derailleur clamp so 700x25s could fit without rubbing
The Viceroy
Bikes: SE PK Ripper FG,Trek Classic Steel, Free Spirit FG, Raleigh Pointe, Centurion Sport DLX, Schwinn CrissCross
Could of gotten this hot mess. I give you the really poor mans SS conversion crankset. IDK why I still have it, maybe it will be wall nostalgia if I ever open a shop.
Quoted: 1332 Post(s)
Liked 398 Times
One time I accidentally rode with a chainring bolt missing, ended up busting another bolt and bending the chainring in traffic. The bolts were a wacky size so I used some regular nuts and bolts to secure the chainring back in place and finished the day on it. Then I rode it for like three more weeks. It also had a bent chainstay from being run over and the bottom bracket was falling apart. That was a good bike.
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
I spy an HP 12c.
One time I was helping a friend clean up a sw33t fixie he bought off of craigslist. When I went to fix the bar angle on the bullhorns by loosening the face plate of the stem and recentering the shim, half of the bars fell to the ground.
Turns out behind the shim that was there, the bars were sawed down the middle. Considering we bought it brakeless, I'm assuming the seller had a death wish. It was a 4 bolt design anyhow.
Had a customer who wanted bottle cages on his suspension fork legs so he drilled through the lowers and stanchions and bolted his cages on, completely locking out his nice suspension fork. We took pictures and sent them to RockShox for a warranty inquiry. Many lulz were had.
Other notable custom drillings by customers: last week a guy's bike with sheet metal screws in his Cervelo P2 top tube to hold his Bento Box in place better; a while back a guy was bragging to me about drilling through his Trek Fuel EX frame and seatpost to install a bolt to keep his seatpost from dropping with his QR seatpost collar; another customer had a broken stem faceplate so they drilled and installed a bolt through the remaining portion of faceplate and handlebar.
And the list goes on...
Quoted: 443 Post(s)
Liked 12 Times
that's what would happen if my dad worked in a shop.....he's a firm believer that anything can be fixed with some self-tappers. most of the time he's right.
Grumpy Old Bugga
Quoted: 370 Post(s)
Liked 8 Times
My dad works on the principle - do it up until it strips, then back off half a turn. He'd do well with carbon bikes.
