Can't fix bike creak
Old 07-02-18, 09:14 AM
bikeClaush
bikeClaush's Avatar
Can't fix bike noise
Hi there guys, so i was on a night ride with my friends, everything was okay, gears where going up and down smoothly until my chain fall from the big cog, i've set the ''L'' limit screw and everything was okay, until a weird sound started, it is from the rear derailleur, but it feels more in the pedals than in the derailleur, so i took the chain off and it wasn't the pedals, tension is right, at first i taught it was the cable, but i took it off and still, the sound was there, i couldn't get rid of it, when i go in the highest gears (small cogs) the sound disappears, i cleaned and lubed my chain, still, nothing. I don't want to change the derailleur, it's a shimano deore XT m750 (I know it's old), and i really like it. The limit screws are right, it's not the b-screw. I don't know what to do, please help me guys. Thank You.
bikeClaush is offline
Old 07-02-18, 09:32 AM
Riveting
Quoted: 590 Post(s)
Liked 445 Times in 260 Posts
So, you don't have a creak?
Riveting is offline
Old 07-02-18, 10:15 AM
Richard8655
Bikes: 2007 & 2008 Specialized Tricross Comp
Quoted: 35 Post(s)
This might help pinpoint the cause:
”If during a ride you hear a creak or squeak once per revolution, it is probably located in the crankset and pedal area. If the noise is once every 2 - 3 revolutions, it may be in the chain.”
https://www.parktool.com/blog/repair...isy-drivetrain
Richard8655 is offline
Old 07-02-18, 11:51 AM
DannoXYZ
DannoXYZ's Avatar
Quoted: 109 Post(s)
Liked 9 Times in 6 Posts
Most likely causes:
1. left crankarm to spindle interface. Use a torque-wrench to install
2. bottom-bracket cup to shell has large clearances. Use teflon-tape to fill
DannoXYZ is offline
Old 07-02-18, 12:14 PM
Kontact
Kontact's Avatar
Quoted: 4409 Post(s)
Liked 1,565 Times in 1,027 Posts
This kind of thing is usually the cassette lockring not being tight enough.
Kontact is offline
Carbonated
Bicycle Mechanics
3
12-04-17 11:58 AM
ivan_yulaev
Road Cycling
9
03-15-15 04:05 PM
Jer81B
Mountain Biking
7
08-17-12 03:02 PM
madmonqey
Bicycle Mechanics
2
04-02-11 08:35 AM
Buggington
Bicycle Mechanics
6
12-06-10 12:25 PM
