Interesting freewheel hub - cartridge bearings
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,100 Times
I’m currently building up a shop spares city bike for my wife. It’s going to be a 7 speed flatbar bike. I have a set of wheels, no name English thread freewheel hub on Wolber Gentleman 81 rims, that have been sitting in my shop for a couple of years awaiting overhaul. I removed the NDS locknut but the cone was weird in that it was pretty tight, so I went to drive side and loosened the “cone” only to find the whole axle threaded out like this. I pried off the bearing seals and they looked pretty good so I stuffed some Phil Wood grease in and put everything back together. Spins pretty well. I’m assuming this is from late 80’s or early 90’s. First time I’ve come across a freewheel hub with cartridge bearings.
Bikes: Teledyne Titan, Bob Jackson Audax Club, Bob Jackson World Tour, AlAn Record Ergal, 3Rensho Katana.
Quoted: 215 Post(s)
Liked 623 Times
A nice very common bearing (SKF 6001-RS1), can be found for about $5.00 each.
Seals, 1
Material Standard, SAE 52100
Bore, 12mm .4724" -.0003
Outside Diameter , 28mm 1.1024" -.0004
Width, 8mm .3150" +.0000/-.0050
Max Fillet Radius, .012
No. Balls, 7
Ball Diameter, 3/16
Static Load, 500 lbs.
Dynamic Load, 805 lbs.
: Mike
Seals, 1
No. Balls, 7
Ball Diameter, 3/16
: Mike
Quoted: 3241 Post(s)
Liked 2,512 Times
Probably Specialized. I have a set. Chrome covers that have Specialized on them. Very good hubs.
Bianchi Goddess
Quoted: 2938 Post(s)
Liked 2,934 Times
You took the seal off. they come out as a unit
Sugar "Kane" Kowalczyk
It's a Sanshin. I think of them as Sanshin Gyromaster because that was the first I saw. Lots of slightly different versions. Sold as SunTour and Specialized. Also sold with no markings at all. Wonderful hubs. Really wonderful hubs. One of best ever.
Quoted: 106 Post(s)
Liked 36 Times
I’ve got suize hubs like that on my 84 pro tour, and a mixed set of Sansin and suntour superbe pro on my prelude that I found at the thrift store. Great hubs all around.
Bikes: Numerous
Liked 3,100 Times
Thanks all, good info. It does seem like a solid hub. No marks on it. These came on a bike I bought but can’t remember for sure which one.
Liked 2,512 Times
Here is my Specialized front hub. The lettering has worn off the dust cover, but the sealed band is still on. The rear still has the lettering, but no band.
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 643 Times
So I presume this is a rare combination?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Liked 2,512 Times
Bringing up the rear.......... with the faded Specialized script.
I'm having the same issue with my DS rear wheel but my dust cover/cone doesn't quite come off. I tried pulling on the cone itself but it seems pressed into the dust cover. Any ideas?
