Used bike or new for randonneuring?
Hi everyone,
I am new to the forum and to randonneuring, so please forgive me for asking such a typical question right out of the gate.
Although I am new to randonneuring, I am not entirely inexperienced with long distance riding. However all of it (including a very hilly century ride this past November) has been on a single speed bike and, at 50, I am looking at getting a multi-speed for the longer distance stuff.
Recently, I was looking at a very nicely maintained early 70s Motobecane (price: ~$400) that I was going to convert to 650b. The frame is Reynolds 531 and the components are very decent (stronglight cranks, weinmann center pull brakes, etc). However, my wife thinks I am crazy and that I should get a new bike of contemporary make, even if it is more money.
So what would you recommend? Am I stupid to consider a 40 year-old bike or foolish to pass up a chance to get a classic ride?
Thanks in advance!
--Eric
Thanks in advance!
--Eric
Quoted: 18350 Post(s)
Liked 4,502 Times
What model of Motobecane? Vitus Tubing?
You might check the tire size of your bike. It quite likely was originally 27". So dropping to 700c, you may be able to mount the tires you desire.
Mounting 650b may be problematic with the brakes.
Isn't part of the sport just getting out and having fun? So, why not?
There are people who modify vintage bikes to take modern components. Or, downtube shifters, bar end shifters, and even stem shifters work very well for shifting gears. No need to extremely fancy.
The one warning I'd say, however, is that French bikes are some of the least compatible bikes with everything else in the world. OK if you're keeping them more or less original, but it could be problematic if you choose to do upgrades of stems, headsets, or bottom brackets.
Bad example
Old steel bikes are wonderful for distance riding. And if they are maintained at all, the frames at least will last forever. I am quite addicted to old French bikes myself and they can make marvelous tourers. The Motobecane you are looking at would be a perfect choice.
Thanks for the comments so far.
Clifford, the Motobecane is a 1973 Grand Jubilee with Reynolds 531 tubing. I am aware that a switch to 650B tires might require replacing the current brakes with long reach double pulls, but happily those seem to be reliably available (eBay for vintage, Paul for modern). I was a little worried about the French compatibility thing too but I see that Phil Woods is making BBs for old French bikes, so that's a relief. The headset (original) on the bike has been repacked and regreased. The one other thing I might want to replace is the stem, so that's a consideration but it seems to be relatively easy to convert 22.2mm stems to 22.0.
Are there other reasons though to prefer a recent make bike over this old steed? I ask because I promised my wife that I'd try to get something like an objective view while knowing full well that there might be some bias among randonneurs/euses for old Reynolds frames and French geometries.
--Eric
--Eric
Liked 4,502 Times
IRD also makes French cups for their BBs.
Quoted: 3452 Post(s)
Liked 1,452 Times
I have a 1961 or 62 Italian bike with Columbus tubing that I occasionally ride. I really like the ride, but I find that within my fleet I ride it very little because of the inconvenience of the friction downtube shifters.
I made several upgrades to the bike, some of these upgrades may or may not be practical with a French bike. Upgrades are as follows.
Everything else is stock including the Mafac brakes, but as noted above the brake levers were changed.
I really like the ride of the bike, but because of the friction downtube shifters, I just do not ride it very much. I just like indexed shifters too much.
First photo, the new handlebar setup, second photo is of the bike, third is the reason I do not ride it very much.
I am now retired and have the resources to make any changes I want. I bought this bike when I was still in college, so it has been an on-going on again and off again project over many decades. I worked in a bike shop before college, so I have done all of my own work on the bike.
The reason I am going through this long list of changes that I made is that you might find that updating an older bike can take a lot of effort and in the end, you do not know if you will still want to use it as much as you would use a modern bike.
And as a hobby, I enjoyed working on the bike but I do not know if that would be the same situation for you.
- When I bought the bike used in the late 1970s, it was badly abused. I have repainted the frame twice since then, most recently was a couple years ago.
- In the 1980s, the early 1960s rear derailleur had a major bolt come unthreaded and a piece of the rear dérailleur was lost in the ditch. I installed a new Nuevo Record at that time.
- And the last upgrade from the 1980s was adding some plastic fenders from that era. Other upgrades were in the last couple years.
- Wheels were 120mm rear hub spaced five speed with tubular tires. A couple years ago I got a great price on a used pair of mid 1980s wheels, 126mm rear hub spacing and clincher rims. I tried to cold set the frame to take the wider hub, but the Columbus tubing was like spring steel and I finally gave up. But I use that 126 spaced hub, it just takes more effort to squeeze it into the frame.
- The original crank with Campy 151mm BCD chainrings was 52/48 and I wanted lower gearing. I installed a Campy square taper cartridge bottom bracket and a Campy triple that was 52/42/30 for better gearing.
- The original five speed freewheel was 13/21, I put on a six speed freewheel on it with slightly higher gearing. When using the 30T granny, the rear derailleur will only work with the largest three sprockets on back because the derailleur cage will not take up all the slack.
- I prefer interrupter brake levers. The original handlebars were way too narrow for me and needed updating. I used modern handlebar, modern brake levers, interrupter brake levers, threadless stem, quill to threadless adapter. The reason I went threadless was that wanted the ability to try different reach, meaning different stem lengths without major effort.
- Clipless pedals.
Thanks for the insight and congratulations on bringing that gorgeous 1961 Ideor back to life!
Like you (I'm guessing because you said you were retired), I grew up with friction rather than indexed shifting, so it doesn't put me off in principle that the Motobecane would be a return to that kind of shifting. Of course, it has been ages since I have had to do it--my regular bike is a single speed--so I will have to see how it feels when I try out the bike.
Again, thanks for the cautionary note though.
Jedi Master
The other thing to consider is if you’ll like it when it’s done. The 650b conversion route has a lot of appeal and plenty of fans, but I’ve met enough people who tried 650b then went back to 700c that it makes me apprehensive to undertake such a project myself. That said, the Grand Jubile is a good candidate if you want to go that route.
There is a current fad/sub-culture in C&V for the conversion of these machines to 650B from simple bolt-on retrofit to full-on bare frame re-furbish w/ a suite of braze-ons, re-raking and custom paint. Take a look at C&V and post a conversion question to 650B on a Grand Jubile where you will get a plethora of assistance from those who having done the conversion, drank the Kool-Aid of 650B.
-Bandera
Randomhead
Liked 3,686 Times
depending on the condition of the motobecane, it probably will be a better bike than a new bike you can get for a reasonable price. My current road bike has a frame I built in 1980. But the only contemporaneous part on the frame is the headset. Which I need to overhaul.
There is nothing wrong with a bike made in the '70s. I rode my first year of randonneuring with my racing bike that I had ridden as my main bike since the early '80s. That bike had a lot of miles on it, many more than the bike I'm riding now.
Does the motobecane have simplex dropouts? That is one thing that I would hesitate over. I have tapped many a simplex dropout to take a modern derailleur, but a lot of people hate that idea.
Quoted: 5766 Post(s)
Liked 2,538 Times
It's not about new or used, but about how well ill or well conceived the bike is. For example, the OP mentions converting a 700c (or 27") to 650b. But the reduction in rim diameter will impose a brake reach issue. Even if the OP finds caliper with adequate reach, the change in geometry will mean far less leverage, coupled with a reduction in arm stiffness.
My rule has always been that not only is it impossible to make a silk purse out of a sows ear, you can't do so even if you start with a canvas purse.
So, my advice is to start by deciding on the basics, such as wheel size, and ONLY consider options that meet that most critical parameter. A used bike with upgrades and modifications can be a great option,but not one totally remade into something it can never be.
FB
Chain-L site
FB
Chain-L site
Jedi Master
^This post doesn't make any sense to me. Lots of people have already done the 650b conversion on the Grand Jubilee. There's no mystery as to whether or not it will work.
Liked 2,538 Times
I didn't say it was impossible. Just that the change will require brakes with significantly longer reach. Specifically the 19mm difference between the 311mm and 292mm rim radii id starting from 700c, or 23mm if starting from 27".
The necessary calipers exist, so it can be done, but the longer reach, comes at a cost in performance, as I described earlier, plus the OP may not be able to find comparably high quality calipers with the necessary reach.
Of course it's the OP's choice, but he might start by measuring the current reach, adding the correction and seeing what his brake caliper options will be.
BTW - if wider tires are the desired outcome, there may be another option. The OP can switch to wide 700c (29r) rims, and shop from a wide selection of tires in that size. This option probably won't call for new brakes, but he'll be limited by fork and stay clearance, so here too measuring is called for before committing.
FB
Chain-L site
FB
Chain-L site
Randomhead
Liked 3,686 Times
Of course, it might not have so much clearance with bigger tires.
Quoted: 182 Post(s)
This is largely a matter of style, no? Modern or old , whatever floats your boat. My next might be a specialized diverge in carbon.
Liked 4,502 Times
Another thing to keep in mind is how much of the $400 bicycle you're actually keeping.
A good paint job can be worth quite a bit. However, if you're planning on brazing on canti-posts, or making other major modifications, then might as well find one that needs a full repaint. Water bottle cages? The Grand Jubilee bikes can go from as low as $100 or so up to your price of $400 or so.
Oh, here you go, perhaps you could bring your wife onboard with the project if you went with this route.
https://www.ebay.com/itm/Matching-Pa...s/112536448790
I think the Grand Touring is one step down from the Grand Jubilee, but still not a bad base bike/frame. There are also Grand Jubilee Mixtes out there, but they are more rare.
I did that for the "Full Campy" effect on my Internat'l and found that they had to come off for mudguard install.
It will take a bit of planning for a 650B conversion as @FBinNY notes but it's "a thing" on C&V and the whole process is well documented, although not my "thing".
-Bandera
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
+1.
@ericjd, you will see lots of special bike projects for randonneuring here on BF, and I love me a bike project as much as anyone, but don't feel like you *must* check all of the boxes in order to ride brevets!
The important things are that your bike be comfortable enough for the whole ride, that it be reliable enough to get you the end, and to have some kind of lighting for the longer rides. Any number of bikes, old or new, can get that job done.
Liked 4,502 Times
How much are you packing for your trips?
One thing I've noticed about my old Colnago is that it is really flexy when heavily loaded on the rear. At least so it seems.
I recently did a drop bar Hybrid conversion (520 steel), and the beast is rock solid with my panniers... at least up to what I've had in them so far. I haven't gone over 50 pounds yet, I don't think. I'm still doing some experimenting on the Hybrid conversion, and will probably eventually choose some lighter tires.
Randomhead
Liked 3,686 Times
anyone randonneuring with fully loaded panniers is doing it wrong, IMHO.
Jedi Master
Apologies if my post came off as rude, but I still don't get your point about the silk purse. The whole 650b conversion thing is pretty well understood by now, and I assume the OP has done a bit of research since he already ID'd french bottom brackets and appropriate centerpull brakes earlier in the thread.
Liked 2,538 Times
It's up to the OP to decide what he's really looking for. A good randonneur bike, or a nice vintage bike suited to randonneuring. There are some trade offs either way, so while anything is possible, the OP needs to decide what he wants.
FB
Chain-L site
FB
Chain-L site
Liked 4,502 Times
I'm still having troubles wrapping my mind around the concept of 700 or 800 mile rides. There is a local 10K that is one-way, so if one is bike commuting, it could make for quite a long ride.
