Seatpost question - Alternative to grease....
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
I just purchased a bike with a CrMo frame and alloy seatpost.
I was advised to lightly grease the post with all purpose white lithium grease to avoid seizing in the seat tube.
I don't want that to happen; however, I would like to preserve my option to switch to a carbon post.
Is there something else I can/should use? Assembly paste?
Quoted: 1438 Post(s)
Liked 1,092 Times
Use grease now, swab out the seat tube with mineral spirits and use carbon paste when you decide to switch to a carbon post.
Likes For dsbrantjr:
Use grease when and if and when you switch to a carbon post use the recommended paste the residual grease wont effect any future choice what ever you do dont fit a post dry
Likes For headasunder:
SE Wis
Quoted: 2747 Post(s)
Liked 3,398 Times
Likes For dedhed:
SE Wis
Liked 3,398 Times
80-90% CAS 64742-54-7
Chemical Name CAS-No Weight %
Petroleum distillates, hydrotreated heavy paraffinic 64742-54-7 80-90
Basically a petroleum product
https://echa.europa.eu/substance-inf...fo/100.059.216
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Friendship is Magic
Bikes: old ones
Quoted: 26422 Post(s)
Liked 10,380 Times
I have never experienced something like that myself, but I don't use lithium grease and it's pretty dry here most of the year.
So I'm in no position to judge the issue, or whether it's a problem at all. I just thought I'd mention it, because any grease (and a lot of the different anti-seize greases) will work.
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,532 Times
I suppose the alternative to grease for the CroMo/Alloy combo is to use eg. Park Anti-seize instead. You don't see it as often recommended for some reason though. And.. there's nothing wrong use Park Assembly paste even if there's no CF involved, though be careful as that stuff can cause scratches to the finish of eg. your seatpost - I usually note with eg. tape wrap around the post exactly how far I'm want to insert into the seat tube, and then smear some of the SAC paste on the inside of the seat tube as opposed to putting on the post.
Liked 1,092 Times
...there have been several people here in the past few years who have expressed concerns about the lithium in lithium grease, as a contributor to galvanic corrosion.
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
The lithium in grease is in the form of a soap formed by saponifying a lithium salt with a fatty acid; there is no lithium metal to participate in a galvanic reaction. Red herring IMO. If there is still a concern use a synthetic grease, I like Permatex Ultra Slick with PTFE. I WOULD avoid copper- or nickel-containing anti-sieze for that reason, but they are designed for high-temperature use like exhaust system fasteners.
I've used this stuff on seat posts:
https://www.autozone.com/greases-and-gear-oil/lubricant-grease/permatex-di-electric-grease-3oz/34495_0_0?spps.s=6233&cmpid=LIA:US:EN:AD:NL:1000000ER:71700000060527801&gclid=CjwKCAiAx_DwBRAfEiwA 3vwZYouudQvXiGw23kV68pKnhstJCySA4jO_zl95zD_s9qb6_as3aLvfnBoCWOwQAvD_BwE&gclsrc=aw.ds
It's clear, thick & sticky. Doesn't make a mess like waterproof grease.
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
UPDATE - Thanks all for your feedback.
Absent any waterproof grease or any other razzu products, I reinstalled the seat post with garden-variety general purpose grease. So far so good, the seat post clamp is not slipping at all, which I am told these QR clamps which come on the Jones bikes are prone to do.
Cheers and hopefully I don't get struck down by the cycling gods for doing so!
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
It's grease. Don't overthink it. Use this. And you could clean it off with min spirits when you use carbon assembly paste, but a quick wipe with a rag and application of carbon assembly past (which is about 10% glass and silica powder and the remainder ... wait for it... grease).
Likes For WizardOfBoz:
