Best Chain Lube?
road siklista
Bikes: Custom Knolly Chilcotin Limited Edition Orange, Dartmoor Wish, KHS 7500, Custom built Specialized Camber, S-Works Road, Cannondale Trail mtb, Polini MTB
i use pedro's....
Linux Geek
Bikes: LeMond Tourmalet Cannodale F400
zeego ...
i'm currently in love with pedro's extra dry, works well for me. of course there are a bunch of threads in the forums on this subject, do a search and get a hundred more opinions
-- michael
-- michael
Bikes: Litespeed Vortex and Cannondale F800
right now I am playing around with voowdew. it is about the slickest thing I have seen. now I am testing it for longevity.
https://www.voodew.com/Falex/Extreme%...re%20tests.htm
Bikes: Lots
I've used Tri-flow on my road bike, but avoid it for my mountain bike. It collects too much dirt and gets UGLY black!
I've use White Lightning with much success. I've also used Finish Line Krytech and it's worked similar to the the White Lightning.
Currently, I'm using the aforementioned Pedro's Dry Lube. This has been a great lube and has worked very well for the road and mountain bike. It's my current #1 recommendation.
L8R
L8R
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
Quoted: 2952 Post(s)
Liked 3,106 Times
Finish Line Krytech.
Quoted: 12195 Post(s)
Liked 1,497 Times
Hi,
I alternate between Prolink and Finish Line Century.
Provides a very smooth feel.
Quoted: 114 Post(s)
Liked 119 Times
Originally Posted by zeego
Ok what do you live by?
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Originally Posted by mr_ed
Bikes: 84 Trek 660 Suntour Superbe; 87 Giant Rincon Shimano XT; 07 Mercian Vincitore Campy Veloce
3 in 1 motor oil is a 20 weight and the 3 in 1 household is 18w oil that like engine oil will attrack dirt like flies to fly paper; again not good for chain life because the grit will destroy the chain; kind of like using no oil filter on your engine.
TriFlow has one poster said is very good, I used it for 20 years before switching to wax...I needed to learn a lesson!! I like to experiment, so after the wax crap shortened my chain life by 100% I got a new chain and started using Speed Skate Lube about 3 years ago. I actually liked it except it came only in a spray and had to wait 24 hours for it dry, so about 6 months later I switched to Finish Line Teflon Dry...which I also learned from my LBS to let it dry 24 hours also then wipe. This stuff holds up real well...at least in dry climates, not sure about rain. I decided to test the Finish Line by not relubing intill the chain made noise, after about 800 miles it still was quiet, but it was black as cole so I cleaned the chain and relubed it. I now clean and relube about every 200 miles.
I had to replace my freewheel about 3 years ago and about a 8 months later I could hear the pawls clicking (this bothered me because I'm use to silence), so I took the Speed Skate Lube and sprayed the freewheel to see what would happen, and the thing hasn't made a sound since!
Remember I said I liked to experiment? Last week I decided to try something, I first cleaned the chain (as I aways do when I relube), then lubed with the Speed Skate Lube, I let that dry for 24 hours, then applied the Finish Line Teflon Dry and let it dry for another 24 hours. So far so good, but it's way to early to tell.
Bikes: Trek 4300 X 2. Trek 1000, Trek 6000
Originally Posted by MudPie
For my mountain bike, it's Prolink! Best dang stuff for the dry, hardpack in Southern California.
Tri flow is very similar to the Pro Link in duration. I think I will be sticking to BoeShield from now on.
I have not found a lube that only lasts 50 miles. myself if you clean the chain well most of the lubes last a long time. but What I am after is long lasting in the rain and the least amount of lube on the chain so it stays clean. that last part is the hardest. no lube o far lasted after I wiped the chin to where there was nothing visible. after that I get a few days riding then it got noisy.
Liked 3,106 Times
Correction (since I looked at the bottle this morning): Finish Line Teflon Dry. As one of the other posters mentioned, it works really well when you let it sit and then wipe. Tri-flow attracts way too much crud in my experience.
Direct Hit Not Required
Bikes: Leopard DC1, Ridley X-Fire, GT Zaskar 9r
Pedros Extra Dry on chain, Boeshield T9 everywhere else.
Looks like I may try Pro-Link or VooDew.
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
I have been using DuMonde Tech for the past 5 years. I recently switched to the Tech Lite for my roadbike though. It's a wet lube but acts a lot like a dry lube.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
