silly design challenge
bironi
Quoted: 98 Post(s)
Liked 292 Times
I have installed some unneeded Simplex retro-friction shifters on my fixed gear.
They are currently just a nostalgic reminder of my love for their effectiveness.
Our local multi-talented frame builder suggested that I deploy them for some other function.
My hope is to use them to ring my Crane stem bell.
I'm pretty sure that I would have to go thru as many iterations to find an elegant design as Edison did with his filament.
Here's a pic.
Have at it if interested.
My preference is for my right hand to ring the bell.
My left is a fused Frankenstein-ish-thang.
Thanks
Here's a pic.
Thanks
Likes For bironi:
Bikes: 1st Track bike: 1978 Speedwell titanium 1st Road bike: 2001 Independent Fabrication Crown Jewel
Quoted: 97 Post(s)
Liked 116 Times
You want to reach down to ring the bell? Now you'll have shifters that don't work and a bell that requires you to move your hand off the bars to ring.
Instead, why not convert your frame pump into a lighter? It would be more practical.
Likes For Biketiger:
Quoted: 801 Post(s)
Liked 754 Times
You could set something up with a cable and a spring, probably...but it being a fixed gear I think the end product would look ungainly.
Likes For Piff:
Quoted: 836 Post(s)
Liked 2,164 Times
A Rube Goldberg competition? Subscribed!
Likes For gaucho777:
Veteran, Pacifist
Quoted: 3902 Post(s)
Liked 4,848 Times
Doesn't sound pretty and certainly won't look practical. And vice-versa.
Fixie? Remove that front brake and route any cable to resemble the housing. Stealth.
Wirelessly actuated bell ringer? Each click on the ratcheting shifter delivers a different bell ringing sequence?
Silly is beyond understatement. Stem shifters would make the job easier. Carrying a decent bell ringer would be more expressive. 2nd bell for a ringing duet? - 2 shifters already installed. A horn more effective, 2 horns even louder.
Hiding wires inside tubes & stems is a thing these days, tough with a quill - but I'm not a silly machinist.
The only sillier 'invention' I know of is @Bianchigirll 's spork on a fork, for bikepackers prone to forgetting their eating utensil.
Bikes: Road: 1972 Raleigh Competition,1989 Marinoni, 1990 Limongi. MTN: 1990 GT Team Avalanche, 1991 Rocky Mountain Blizzard, GT Team RTS , Rocky Mountain MSL 50 Element, CCM fat bike
Quoted: 35 Post(s)
Liked 81 Times
How about if the levers deployed a "Flick-Stand" type of device with the levers? Maybe put them on backwards so the swing down and prevent the front wheel from turning at the headset when parked.
Quoted: 3015 Post(s)
Liked 3,809 Times
Do you want the shifter to stay in place and have the bell move? Or do you want the bell to stay in place and have the shifter move? Is drilling holes into things acceptable?
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
A few of the SS/FG guys have done that. Some bells can thread onto a downtube shifter boss. I looked for pictures on BF but links are broken.
Quoted: 225 Post(s)
Liked 1,101 Times
For a taught enough connection to flick the bell, seems like you’d need to move the bell from the stem onto the frame somewhere - maybe where the FD would mount. Otherwise, you’d need some sort of connection that allows for the stem rotation. Would it work to go ahead and mount the bell upside down in the FD location and just route a cable from the lever back up to the right shifter with enough tension so you could just flick the shifter lever to ring the bell.
Good luck, I had fun rigging dummy thumb shifters (concealing the rapid fire shifters) to cheat my way to Cino stamp last year.
Montana, where men are men and sheep are lying little tramps.
Quoted: 4808 Post(s)
Liked 3,938 Times
I'd leave as is as long as you don't have the issue of brushing them with your leg as you climb out of the saddle. (I do and most of my shifters have gone DT top mounted on my derailleur bikes.)
Big plus - when you get on this bike after time on your other bikes, when you reach down to shift, there will be something there! Plus you have all the benefits of those clean DT shifters, the looks, the light weight and now, no exposed cables to scratch that beautiful paint when you pick the bike up.
Quoted: 554 Post(s)
Liked 3,794 Times
Turn them into Turn signal actuators!
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,482 Times
Fabricate a perch for a small parrot attached to a downtube bottle boss.
Run cable from shifter to Parrot's tail.
Activating shifter pulls cable, tugs parrot's tail. Parrot squawks!
Who needs a bell?
Brent
Who needs a bell?
Brent
"I have a tendency to meander sometimes." B.G.
Likes For obrentharris:
Likes For Piff:
Likes For Mr. Spadoni:
Likes For velomateo:
seńor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3893 Post(s)
Liked 6,491 Times
Simplex retro-friction shifters... My hope is to use them to ring my Crane stem bell.
Likes For SurferRosa:
bironi
Quoted: 98 Post(s)
Liked 292 Times
I'll be in Saddam Hussein's desert hole waiting out a solution, or perhaps riding around dinging my Crane bell mounted on my stem like it is on all my bikes.
I'm a little saddened by the true lack of bike geekiness here in response.
Back down in the hole.
Later.
By
Later.
By
Quoted: 4560 Post(s)
Liked 2,802 Times
Here's a pic.
Thanks
Here's a pic.
Thanks
Instead of rigging the bell to the shifters, I'd rig up some Roman candle launch tubes and sparker from Bic lighters to the shifter levers as ignition sources. Plenty of times I'd be awful tempted to retaliate against hostile drivers with some fireworks.
Quoted: 1627 Post(s)
Liked 630 Times
My new favorite use for Di2 technology.
Thank you, Wildwood.
Likes For Lascauxcaveman:
Bianchi Goddess
Quoted: 2938 Post(s)
Liked 2,934 Times
Here's a pic.
Thanks
Here's a pic.
Thanks
Second it reall needs to turned back into a “10Speed”.
as to the shifter ringing a bell….. I think you need a rotary style bell that chimes as you push the putt on/lever and again when you release it.
Sugar "Kane" Kowalczyk
Bianchi Goddess
Liked 2,934 Times
Likes For Bianchigirll:
Likes For mtbikerjohn:
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Happy to buy those shifters off of you and use them for their intended purpose, them being so good at it (and me regretting selling the pair I had several years ago when I lost my job).
I do like the Di2 electronically activated bell. Use an Alfine setup since only one lever has button functions (keeps it simple) and Di2 Alfine is not exactly the most popular thing (aka discounts on new/low prices on used).
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1229 Post(s)
Liked 3,565 Times
Likes For AdventureManCO:
