160mm to 203mm
160mm to 203mm
I’m wanting to convert my front and rear rotors from 160mm to 203mm. I know for the front I need the post mount to post mount +43. I was wondering what the link or product code for the is to is mount +43 was
Quoted: 184 Post(s)
Liked 67 Times
This is a 160 to 203mm post to post adapter.
https://www.jensonusa.com/Shimano-F2...-Brake-Adapter
Is your fork rated to use a 203mm rotor?
If I was to convert the rear to 203 from 160, what adapter would I need. I ordered the sm-ma-r203 s/s and it’s the right adapter but the calliper doesn’t fit on the adapter. The fixing for the calliper is on the chain stay not the seat stay and the up label on the adapter isny facing up
Quoted: 184 Post(s)
Liked 67 Times
Does the frame have IS mounts?
Does the caliper have post mounts?
Do you need a 203 on the rear, could there be any possible issues with attaching a 203 on the rear?
What's your frame?
The frame is IS mount and the calliper is also IS mount. The frame is a cube aim race 2020 The adapter would fit but the calliper won’t sit flat on the adapter and only one hole lines up with the adapter and calliper
Quoted: 713 Post(s)
Liked 796 Times
By the way, 203mm brakes are way overkill on that bike. They are only used on Downhill bikes and tandems. There is also a good chance that there will not be room for the brake caliper to fit under the seat stay with that size adapter.
Quoted: 184 Post(s)
Liked 67 Times
https://www.flickr.com/photos/kyomor...phy/4933408196
Specs say you have Shimano brakes, they haven't made a IS mount brake for over 10 years.
SR Suntour recommends a maximum rotor size of 180mm for the fork on your bike.
Cube says you won't have any warranty if you put on larger rotors then they supplied.
Are you actually having any problems with slowing down or stopping?
Quoted: 136 Post(s)
Liked 57 Times
I had 160s F and R and upsized the front to a 180 and it's plenty. I ride XC/Trail not enduro or DH. I can tell the diff with the 180 (the max for my fork)
Quoted: 1188 Post(s)
Liked 1,154 Times
Then there is the issue that Suntour XCM forks are only rated for 180mm...
What kind of riding do you do? 180 front and rear should be plenty. Current brake setup?
