Help understanding angles for tube notching
Hello all, Thank you for reading and helping!
I am having hard time understanding the online notching calculators.
Most calculators present the following:
Diameter of cut tube: This is ok
Wall Thickness of cut tube: This is ok
Diameter of parent tube: If I understand correctly this is the tube that I won’t be cutting.
Angle: I don’t understand what value to use here, for example: The HeadTube is at 75 degrees to horizontal and the TopTube (The tube I want to cut) is at 30 degrees to horizontal ?
Offset: I don’t understand what offset is and how to use that parameter ?
Thank you very much,
Tom
Tom
Quoted: 714 Post(s)
Liked 800 Times
Parent tube is the uncut tube. Horizontal doesn't matter. You need the angular relationship between the two tubes. Most frame design programs will give you those angles.(I use RattleCad) Offset is the distance from the centerline of the tube and will provide an off center miter. Most tube miters have a zero offset. Offset is helpful for things like moving the seat tube forward on the bottom bracket to provide more tire clearance. I also offset miter my chainstays to make them lower on the bottom bracket for ease of welding and to prevent them from contacting the seat tube.
Quoted: 321 Post(s)
Liked 263 Times
That's interesting. The only ones I offset are the seatstays where they join the ST, otherwise they would intersect each other. Never thought about offsetting chainstays or or the ST to BB.
Thank you very much for the answer.
I understand now the parent tube and the Offset.
About the angular relationship i am attaching a link for an image, is that what you meant and if so. what angle i should go for ?
photos.app.goo.gl/3BStSXneAPLUSTvM6
Thank again,
Tom
Thank again,
Tom
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
For the angle I would suggest experimenting with your 76.67 degree top tube joint, printing out and fitting it up to make sure it looks right. You may need to use the 103.33 angle instead. Some programs start the 0 degree at the top or the bottom (for lack of better reference), This is a situation where having it in hand really helps.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Randomhead
Liked 3,698 Times
I don't think it will matter. If it labels top or bottom, they will be upside-down if you do it wrong.
Quoted: 4206 Post(s)
Liked 3,867 Times
These offsets can be helpful when fillet or welding to avoid overlapping tubes. Thus one can construct the joint one tuba at a time and/or insure a tube's complete diameter is contacting the BB shell, Andy
AndrewRStewart
AndrewRStewart
