Please Help Identify Mystery Bike Zeus Dropouts
Hi Everybody, First time poster here, been searching the internet for days trying to find clues about this frame. I found this forum and it has a great community so I thought I would post here.
I have purchased a frame that had zeus dropouts and headset besides that I cannot find a zeus frame that is identical to this, after reading through various posts here there was mention that Raleigh and Carlton used zeus dropouts but I cant for the life of me match it to any 1 particular model.
Some of the noticeable features it has BCM of the head 'lugs' has zeus dropouts both front and back and after removing some of the respray there is green underneath. I didn't manage to find a serial number on the bottom bracket.
Have attached some pictures, any help is very much appreciated
Thank you
Thank you
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Does the frame look anything like this? Look at the lug shapes, the rear brake arc and the chrome. This is a 1971/72 Competition. This didn't come in green, but there was a 1969-ish version that came in a deeper green. I am not familiar with what dropouts those had.
Other Green Raleighs of the time included Internationals and Super Tourers.
You could buy Zeus frame parts, without being a Zeus or even Spanish made frame.
I used a Zeus Fork crown on the bike frame I built in the mid 70's ... & a Cinelli BB & Campag Dropouts..
Bikes: Condor, Cinelli SC, MKM Metcalfe, Peugeot AE08, Bianchi, Cougar, Miyata, Harry Hall, Holdsworth Special, Raleigh Int'l, Le Croco, Bob Jackson, Zeus
Quoted: 114 Post(s)
Liked 102 Times
Zeus fork ends and dropouts
This 1976 Condor Sienna (British) was built in Italy out of Columbus tubing withZeus fork ends and dropouts.
cheers.
Brad
cheers.
Brad
Better bike .. Better life!
Likes For Stevensb:
The other part that was hard to find on the internet was if this had the indents on chain stay as my bike does not have them.
I have attached photos now. Thanks for all the photo and reply, really appreciate it
Hey fietsbob,
Thanks for the reply! Yes I read about this also and could quite possibly be a custom frame. Just got this voice in my head telling me to find out for sure or as for sure as can be.
Hey Brad,
Super clean bike! Mine does not look like this. The forks and the rear forks (not sure the correct term for this) where it meets the seat post is also different in design Thanks for the reply!
Likes For sdee:
Señor Member
Liked 1,090 Times
I see some similarities with my Competition, ("rapid-taper" chainstays - which aren't crimped), but I also see differences - the most disqualifying of these being differences in the head tube lugs, so I rather doubt you have a Raleigh Competition with some braze-ons lopped off and chrome removed. I think there's a pretty good chance that this isn't a Raleigh at all, but with them having made so many variations of things - especially in the early 70's with parts shortages - that I can't say for certain.
Might you have a serial number that you could share the location and format of?
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
BCM long point headlugs and the fork with Vagner crown BUT all the extra washers on that Zeus HS makes me wonder if the fork is OEM, could be IF the HS is a much shorter-stack replacement and it DOES have Zeus forkends, but....unusual. Looks like a pretty nice frame, no idea of a make but if there's a serial number it will help PLUS what's the threading (BB Shell and fork) and size of seatpost?
Yes I was wondering why the fork stuck so far out (looked strange) I’ll try to hunt down the serial number, but no obvious sign of it. Not sure about the threading or how to check it myself. I’ll take it to the local shop and see if they can tell me and report back.
the seatpost is 27.2
thank so much for the reply!
Liked 1,062 Times
27.2 seatpost is a good size to have (indicates most likely something like 531 DB tubing) do you have any spare BB cups that are marked with BSC, BSA, or 1.37 x 24 you can do a test screw-in? I'm guessing this has Imperial tubing so most likely that will be the BB threading too (AKA: British, English, ISO) but ya never know!
Señor Member
Liked 1,090 Times
Thanks for the info this helps a lot, nice to know some of the extra terminology of certain areas of the bike(Rapid Taper, Braze Ons) I have tried to remove the paint on the bottom bracket where I thought the serial number would be but I can’t see any stamps. Maybe I’ll have to completely strip the paint off and do a more thorough check. I’ll try and do this over the weekend. Thanks for you help!
Quoted: 3811 Post(s)
Liked 3,338 Times
lug pattern is BOCAMA Super-Professionnelle
shell is BOCAMA Professionelle
crown is Vagner model DP+
for a Tube Investments product of this era one would expect to see a no-slide pibb and a chainstay stop
of course these could have been present and were removed. if this were the case one would expect to be able to view the evidence with frame in bare metal...
interesting to note that chainstays are pinned
when you have head fittings disassembled you could examine interior of head tube for any indication of head emblem fastener holes being filled in
use of Zeus bits and rapier pattern chainstays in Britain was not confined to TI at this epoch
Liked 1,062 Times
so with a 27.2 seatpost and (TBC) British threading (I know, that's TBC) are you thinking this could be Vitus tubing? Some other brand (but not Reynolds 531)?
BB test
I ended up trying a BB 1.37 x 24 and it fits its screws in counter clockwise on the drive side and clockwise on the non drive side. That was nice to figure out so thanks for the tip! Would this mean it is in fact imperial tubing?
Yes I noticed the nails through the BB into the chain stays and wasn't sure if this was 'normal' or not for a bike this age. Is there any particular meaning to this method?
I removed the headset to see if there were any holes for a badge, from what I can see It doesn't seem to have any.
The fork does seem to protrude alot hmm what would be the best method to put this together without using spacers?
How does Vitus and 531 compare?
Thanks Again for the info and reply
Liked 1,062 Times
They compare very favorably, at least the 172 and 971 are very much in the same ballpark as far as metallurgical composition (well maybe Chrome-moly vs Manganese-moly) and the wall thicknesses, Vitus 980 is even thinner and lighter, more akin to Reynolds 753. They only certain proof is if you strip this down to very bare metal you MIGHT find some tiny faint stamps in the tubes that will say Reynolds 531 DB, not certain if Vitus did this on their tubes. But yes this is British/English/ISO threading and combined with the seat post size and other features including the Zeus ends it sure seems most likely to be British-made, but no idea from me of the make, this doesn't tic the boxes of any well-known Brit brands. EDIT: just saw another thread that asks "did Vitus stamp their steel tubes" and apparently, yes they did but it's seldom seen or recorded, there's an example of "SUPER VITUS" stamped on a fork blade....
Likes For unworthy1:
Liked 3,338 Times
Thanks for the reply and informative imagery! I did see the lug images but wasn't sure because there was no die cut in them which threw me but nice to know the exact bottom bracket used.
lugs -
the BOCAMA Super-Professional lug pattern was offered both with and without the cutouts; hence your confusion.
"nails" -
this method of construction is referred to as "pinning" and frames exhibiting it are said to be "pinned." simply a means of holding all the bits in place in preparation for brazing; neither a plus nor a minus.
steerer length -
if fork ends match dropouts do not think it a replacement. possible it was made for someone who wished the option of running a clamp style headset which requires the additional steerer length. clamp style headsets were pretty much gone from the scene by the time this was fabricated in the mid-to-late 1960's.
now that you have the head fittings disassembled you could closely examine the steerer under strong illumination to check for a tubing maker's mark and/or a serial number. sometimes the markings are struck quite lightly and one must check in good light to view them.
forum member MauriceMoss , AKA "Detective Chief Inspector Moss" , may drop in on his next forum sojourn; for the enlightenment of us all with respect to the frame's identity.
Likes For juvela:
lugs -
"nails" -
steerer length -
lugs -
"nails" -
steerer length -
okay will have a closer look at the steerer I didn’t manage to spend enough time on stripping the paint off so will have to continue and update you all once complete. What was interesting is that it seems underneath the paint it wasn’t all green. Have attached a photo.
