First Time MTB Freehub Replacement Advice
Hello! So I need to replace the freehub on my 4-5 year old Diamondback Heist 1.0. The problem is apart from my inexperience with this is that I'm also struggling to find the right/compatible replacement.
The technical specs I can find for the bike list the rear hub as being a "Diamondback Sealed, QR, 32H" and nothing else - looks to me to be a generic brand build as there are no identifying logos or numbers of any kind on the hub or freehub itself.
(I can't post pics up as this is my first post!)
It's an 11 speed bike and I'm pretty confident I can match to the cassette but I'm struggling with matching to the hub. The majority of the drive is built from Shimano apart from the cassette was Sunrace although I have since replaced this. I need a screw in type of freehub and I can't find many of these out there. I also want to upgrade to a steel one rather than aluminium due to the bite wear,
If anyone can point me in the right direction I would appreciate it. On another note I've managed to get the freehub off with a 12mm hex but I can't get inside it - this was purely out of interest to see the insides and the state of the pawls as it's skipping when I put heavy pedal pressure on and therefore why I believe I need a new one.
I also know there's probably not much difference in price between buying just a new freehub and a whole new hub or even wheel but I'm seriously limited for funds and will be cutting into my households basic budget for the parts but I need my bike to get to work so getting just the freehub seems like the most cost effective way forward.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Took 30 seconds:
https://www.bikeshopwrexham.co.uk/diamondback-heist-1.0
Are you sure it's 11 speed? Info above says 10 speed.
Thats odd, I've never come across that version before when looking for the info online - regardless of that I can confirm it is indeed 11 speed and the link you gave is to a slightly different version.
Mine is;
fawkes-cycles.co.uk/2485159/products/diamondback-heist-10-mtb-275-blue.aspx
trying to get round not being allowed to post links yet!
Mine is;
Quoted: 1572 Post(s)
Liked 643 Times
What exactly are you wanting to replace and why? Just the free hub body or the whole rear hub?
To clarify, the reason I need a new freehub is because after 4 years of riding I think it's internal mechanism is worn. When I put a decent amount of pressure on the pedals (ie: going uphill or gaining speed) it's not engaging with the wheel and slipping.
Seems to be a common issue after a while with cheaper aluminium hubs.
SE Wis
Quoted: 2742 Post(s)
Liked 3,389 Times
Have you asked Diamondback?
https://www.diamondback.com/contact-diamondback-bikes
