Crank removal problem - Bontrager SELEC - Trek 7.5FX
Greetings from Brussels, Belgium! I have been trying to remove the crank from my Trek 7.5 FX (2006 model) but have not yet found how to do so. Once the dustcap is off, it is hollow from one side to the other and thus a normal crank removal tool will not work as there is nothing for the tool to push against. My LBS is closed for the moment and I don't know whey they will be open again so any help would be much appreciate. Thanks. Alec.
I am guessing that the crank is a shimano. After you remove the plastic cap from the nondrive side take off the two allen screws and the arm will come off. Then pull the drive side out.
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 204 Times
I have a 05 7500fx that has that crank. My crank remover has 2 tips; I used the larger one for this crank.
https://www.parktool.com/product/uni...ttom%20Bracket
Last new bike 1991
Last new bike 1991
Quoted: 184 Post(s)
Liked 204 Times
It is a Bontrager with Truvative BB. (similar to Octalink)
Last new bike 1991
Last new bike 1991
Quoted: 184 Post(s)
Liked 204 Times
Make sure the coins are not too snug with the crank threads,
Last new bike 1991
Last new bike 1991
Like this?
like this?
external bearing cranks the left arm clamps around the spindle tube holds it together, the tube is part of the right arm..
the left side cap is the bearing pre load adjustment , in the same manner as the top cap on the steering tube is the headset adjustment.
